richpjr
- Jul 26, 2002
Brian,
I just checked the Stefan Arts web site and they are listing all 3 of the cables I mentioned. The Vision 1 sells for $69-$79 (depending on the length), the Nightpath for $59-$69, and the Equinox for $109. One kind of interesting thing is that the Equinox for the 600 sells for $189. Looking at the description, the 600 version is described as a 4 conductor cable while the 590 version as a 3 conductor cable. How significant is that? Is that why it is more expensive or is it because of the split cable at the end vs. the single connector on the 590s?
As to my very quick initial impression - no I don't think they sound too bright at all. I burned them in for about 45 hours before listening to them and I am quite pleased with the detailed, punchy sound. They are head and shoulders better than anything else I have.
I really have not had a chance to test them for very long, but I did notice a hefty difference between the output of my NJB3 and my Pioneer Elite receiver, as one would expect. That has just reinforced my thought that I need an amp (since the Pioneer is in a different room from where I will be primarily using the NJB3) even for the 590s.
Rich
Rich
