Yamaha HPH-Pro 500 Review
May 23, 2022 at 6:34 AM Post #137 of 139
Murat
Got some generic 85mm x 25mm sheep skin pads for my Pro500: https://item.taobao.com/item.htm?spm=a1z09.2.0.0.636a2e8dWfiX6g&id=566987838274&_u=44r4gfd4074
It could be the best fitting replacement pads for the Pro500. Sound is very close to stock.
Hı borrego, thank you for mentioning these lambskin pads. I just rediscovered how beautiful my pro500 sounds after my deezer subs. upgrade and want to try these but the page is in Chinese I think. Could you help me get these on an alternative site or show me if there is a way to complete the transaction in English?
May 23, 2022 at 10:53 AM Post #138 of 139
borrego
I find a shop on Aliexpress selling similar lamb skin earpads: https://www.aliexpress.com/item/400...f16533175019343733ee0af!10000000860469325!sea
The Pro500 should use the 85mm size.
Cheers!
May 24, 2022 at 2:06 AM Post #139 of 139
Murat
Wow man thanks for the quick reply I will see if that will spread out some of the pressure applied by the cups. My only concern is the heat building up inside the cups due to leather pads because I am planning to put these to replace AKG K540 pads.
