tienbasse
- Dec 5, 2011
Glad you like them, eke2k6.
And for the record, even in my review, I never said there were perfect of anything like that, I actually NEVER use words like "the best", "unheard of", "legendary" and other superlatives...
When I review, I focus on comparisons because my idea is to differentiate IEMs, not to deal in absolutes.
Actually, for my taste, I even found slightly better IEMs with Shure SE535 Red Special Edition, but for nearly 3 times the cost of EPH-100.
So unless my persuasion power is so exceptional that I could convince 15 people that EPH-100 are very good IEMs, I honestly think that it is not just another FOTM. And to be accurate, I know at least 2 people here who didn't like them, so not everything's perfect.
Also... to whoever it was that was highlighting potential fit / comfort issues with these:
Yes, they do look a little unconventional on paper. However, after over a week of using them I feel confident in saying that they are the most comfortable IEMs I've owned. I have small, awkward ear canals, and have all manner of problems with most universals. The only two iems I'd consider truly comfortable are these, and the GR07s. This is an even more remarkable on the Yamahas part, considering that the vsonics have a swiveling nozzle that adjusts to individual ear canals.
The thing is: it doesn't matter that this IEMs are 7mm wide, this is a very small form factor when compared with other IEMs because the whole casing is that small, so you get the luxury of chosing how you angle the IEM to insert it, which you CAN'T do with most IEM having a thicker outer shell...
I have big ear canals, but my right ear is taking a weird 45° angle which my left ear doesn't have. I have a lot of trouble getting a proper right ear fit with most IEMs having a large case (especially Shures and Westones that are said to be very comfy around here).
With the Yamahas, I align the right casing with the bend and I can insert it beyond the turn. I just can't do that with my Shures and Westones, so I have to find tips which can either take this turn (rare large triple flange because usual ones are too small) or tips which are short enough to fit before the turn (large Shure silicone olives and they're barely big enough to seal).
Comfort is really the last of your worries with the EPH-100. Also, do you know many IEMs delivered by FIVE tip sizes ?
