fufula
- May 20, 2007
I am looping this to HQ. Can you please try the following:
[size=10pt]Disable "SPDIF Passthrough Device" in the control panel[/size]
[size=10pt]Disable GX[/size]
Let me know if that helps. If it does not, then will likely need full config details including all relevant driver and software info.
-Raja
I keep both disabled at all times. The problem persists.
Also, I've always had the onboard sound disabled and rolling back to older driver versions does not help.
