My SuperDual arrived today. Wow, fast!
Here are my ULTRA ULTRA PRELIMINARY impressions, obviously with little time for true critical listening and before any burn-in whatsoever.
My other amps are SuperMini 6.0 and 9V portable PIMETA (JMT-built, 8620-based). Tested with ER-4P's converted to ER-4S with "Imped" switch on SD and with 4P-4S cable on the other two.
* Substantially better detail than SuperMini, and just better all around
* Less warmth and less bass power (w/o bass boost) than PIMETA
* In passages that are both loud and complex, SD can sound a little distorted/clashy, while PIMETA remains clean
* Overall: SD a good step up from SuperMini, but not quite as musical and nice to listen to as the PIMETA
Again, this is on zero burn-in for the SD.
Features:
* Bass boost is a bit too much for my taste. Not outrageous, just more than I want.
* X-Feed is nice. I never liked the crossfeed on my AirHead enough to use it, but will use X-Feed sometimes.
* "Imped" switch is sonically indistinguishably from 4P-4S cable, at least in my very limited listening test.
* Volume switch is a "nudge upwards to go up a step, nudge downwards to go down a step, repeat until you're at the sound level you want" design, as speculated/discussed earlier in this thread.
* Power switch is small & a little cheap feeling, but very unlikely to turn on by accident.
Superficials:
* Smaller than SuperMini in length and width, but a bit thicker.
* Power jack is in front of the headphone jack instead of behind it. I would have preferred the other way around. Not a big deal.
* Mini-mini cable that came with mine was a beige Radio Shack straight plug model. Hmm, OK, but I like the Plastics One mini-mini sold by Headroom (black, right-angle plugs) better.
* Battery inside mine looks black, can't see the "Energizer" lettering that I worried about in an earlier post
* Would have preferred a blue LED to red, oh well, no biggie
Overall: I'm very happy with it. While I think the PIMETA is a bit nicer-sounding (at least at this stage of SD burn-in), I will have no trouble doing a monthlong trip later this summer with just the SD along. And being able to leave the 4P->4S cable behind will be a nice plus.
I also tested with my AKG K271s. These phones seem to like amps that can supply a bit of current. With PIMETA and SD (both running on 9V rechargeables), sound was detailed but thin. With the 3xAAA SuperMini, sound was predictably less detailed, but had more warmth and presence. (In other words, no real surprises with the K271. I think 9V battery amps just aren't the right recipe for that phone.)
