Xiaomi In-Ear Headphones Pro HD (2 +1 Hybrid)
post-13167664
Post #376 of 874
astromaddie
What tips are you using?
As any IEM, I feel getting a good tip is important. I'm currently on Complies to tame the sibilance abit.
I'm using the JVC Spiral Dots. I actually didn't find any distracting sibilance, it wasn't more the fit (from the wide base just below the tips) that really bothered me.
They make decent enough office IEMs because I can still hear around me, I just don't particularly like them.
post-13168956
Post #377 of 874
snip3r77
I feel you need to get the right fit. It's definitely V-shape but you get good bass rumble with good enough details from this US$20 and the built quality is superb.
post-13170523
Post #378 of 874
basefi
how does the gen 5 compare to gen 2 in terms of bass and overall sound??
post-13173015
Post #380 of 874
mantex
Someone has used the 1more app for burn-in? how long last the last 3 phase of the burn in?? the first phase last 12 hours and the others?
post-13179999
Post #381 of 874
toddy0191
North East England
North East England
Just received my pro hds today.from Gearbest for £16 and have to say they are better than I expected from reading the feedback on here.
I've been listening via my xduoo x3 with some foam tips which help reduce the highs and adds more bass
Pros for me are the soundstage, clarity and resolution, imaging is great and they have a nice amount of sub-bass.
Cons; they're on the bright side and it's difficult to get a good fit as they are large and awkward shaped.
For the £16 I paid they are an absolute bargain.
post-13183103
Post #382 of 874
denfi
Has anyone taken calipers the the eartip mounting flange? What does it measure out to? Looking to order some foam tips as well as some spinfits to play around. My HDs are still on the slow boat.
post-13204632
Post #383 of 874
singledot02
dual dynamic is setup of compound dynamic driver. Dual dynamic is in dunu-2002 and many subwoofer
What dual dynamic does is it have subwoofer at back of subwoofer consequetively..the moment both are powered, front subwoofer feel infinte air in its enclosure as back subwoofer throws air with the same timing behind the back of front subwoofer.
The moment its done like this...the front woofer can now extend more foward and backward due to air pressure restriction removed from its back plus a little faster.
This sort of bass is more deep and accurate
Whereas 2 driver is like crossover but front to front.
Something like coaxial driver.
It gives the feeling of full range but one is for bass and one is for mids.
Sound better than full range but lacks smoothing of sound and crossover colours it.
Bass seems hollow if bass driver is small at back
you pro bro
post-13206384
Post #384 of 874
Ipse
Just received mine yesterday and despite knowing what to expect from this thread, I was still blown away by the quality of manufacturing and sound.
Unlike others here, I don't feel that the sound is too bright - to me it's just the right amount, naturally rendering the highs.
Bass is excellent, especially when applying the vent port taping trick...maybe even too bassy in quiet environments.
Since I use them on my daily commute, I don't think I could have done better for the 20USD I paid in December.
I appreciate all the feedback and comments in this forum...
post-13208317
Post #385 of 874
fuzun
Is it really that different from gen4? In my opinion gen4 is a thrash like beats.
post-13209170
Post #386 of 874
Marco Angel
Mexico
Mexico
Both are quite good, if you compare vs the Beats, they are quite pricy for what you get with them.
With the Pistons, hybrids, they are a steal, gen 4 sound bassy with less mids and treble, but they also sound detailed with good amount of global definition.
The PRO HD sounds even better, less bass but deeper, more mids with a more organic sound and depending on the tips, a detailed treble or harsh treble.
Excelent purchase.
Reactions: fuzun
post-13210911
Post #387 of 874
snip3r77
Tape the port. What does it do ?
post-13210948
Post #388 of 874
TheGiolly
They are in flash sale for only 25$ free shipping on GearBest!
http://www.gearbest.com/earbud-headphones/pp_566702.html?lkid=10339624
Should I buy these? I already own Piston 3 and Hybrid
post-13211830
Post #389 of 874
Kyrts
Wait for next gen.
post-13211942
Post #390 of 874
fuzun
Use EDM2017 code for -10% more if you will buy it.
