If you look at the photos... dual ESS dac chips, so no plug and play dac like the pro.If this new green thing has an R2R option DAC this could be quite a winner, R2R DAC with real tube amp usually equals lots of joy!
Xduoo XD05T "Portable" Dac + Tube Amp
- Thread starter grant0317
captblaze
Trying this amp out with Senn. HD700 and it is one of the better amps I own for this HP. Liking the instant on. Not getting "tube" hot like other amps I own. Battery life is on the low side but getting 4 hours through 2 charge cycles. Will switch to external power and see what difference if any it makes on sound.
All in all, this is a good amp/dac and if it were under $400 would be an easy rec
I just bought one after seeing Andy's review. I'll be using it with a planar IEM (Shozy P20, sensitivity 105dB at 1kHz/mW, impedance 30Ω) and I hope I won't hear any buzz or hiss... just heavenly music.
Fingers crossed!
Fingers crossed!
captblaze
So far it has been desktop and headphones only, and no hiss or noise that I can perceive on both battery and ext. power supplyI just bought one after seeing Andy's review. I'll be using it with a planar IEM (Shozy P20, sensitivity 105dB at 1kHz/mW, impedance 30Ω) and I hope I won't hear any buzz or hiss... just heavenly music.
Fingers crossed!
Very good... I guess with your Sennheiser HD700.So far it has been desktop and headphones only, and no hiss or noise that I can perceive on both battery and ext. power supply
Do you have any chance to test it with an IEM?
I think both Andy and @ToneDeafMonk are good reviewers.I just bought one after seeing Andy's review. I'll be using it with a planar IEM (Shozy P20, sensitivity 105dB at 1kHz/mW, impedance 30Ω) and I hope I won't hear any buzz or hiss... just heavenly music.
Fingers crossed!
I bought the Onix Alpha after seeing their reviews and iBasso DX180 after talking w ToneDeafMonk...
(Now if I can only get him to say Tabernack ?sp? on one of his videos... )
I think I'd go w the Pro over this... although in the winter... would be nice way to keep warm...
captblaze
I will eventually but the main purpose is to bring some tubes to certain headphones that I wouldn't worry about taking out of the houseVery good... I guess with your Sennheiser HD700.
antanast
What happens when the tubes burn out? Can you replace them?
I don't believe so.What happens when the tubes burn out? Can you replace them?
These are miniaturized tubes that were from the 60's used for military applications.
antanast
So you are spending 500$ with something that will burn out… doest make sense for meI don't believe so.
I read before that these tubes have a lifespan of 50,000 hours, so leaving them on 24/7 would last almost 6 years... I'm more concerned about the end of the battery life (as for any device I own), which I imagine I'll have to unsolder and replace, since I don't think there's a socket with a plug. But to avoid causing damage, I could also consider it as a desktop solution, always plugged into the power outlet.So you are spending 500$ with something that will burn out… doest make sense for me
Unfortunately there are no eternal electronic devices, you have to live with this eventuality, not thinking about it too much and enjoying it in that moment.
antanast
Thanks! I was between this and the hugo 2. Hugo winsI read before that these tubes have a lifespan of 50,000 hours, so leaving them on 24/7 would last almost 6 years... I'm more concerned about the end of the battery life (as for any device I own), which I imagine I'll have to unsolder and replace, since I don't think there's a socket with a plug. But to avoid causing damage, I could also consider it as a desktop solution, always plugged into the power outlet.
Lol!Thanks! I was between this and the hugo 2. Hugo wins![]()
The Hugo 2 is a completely different beast… also they stayed w micro usb rather than update to USB C.Thanks! I was between this and the hugo 2. Hugo wins![]()
By the time the tubes burn out, you would have moved on to something else… also if you could get matched tubes… you could solder them in yourself but probably not worth it unless you are into electronics as a hobby.
- Jul 3, 2013
I'll just leave these here:
