XDuoo XD-05 Portable Dac/Amp Introduction - Impressions
Discussion in 'Portable Source Gear' started by h20fidelity, Dec 3, 2015.
Tags:
88 89 90 91 92 93 94 95 96 97
99 100 101 102 103 104 105 106 107 108
  1. Bhargu
    They are called 3M Dual Lock. I had used them as mounts for my DAP before. I stuck them all over the place, like bed stand, mobile case, table, amp, etc., so that l could 'mount' my DAP and it won't slip and fall.
    misteral201103 likes this.
  2. Onik
    I just received the silver one and once I opened it I see no silmic ii caps.
  3. Holypal
    There is a firmware update for XD-05, fixing DSD payback problems. If no DSD native playing, you don't need it.
    https://drive.google.com/open?id=1t5bgxUBlidGOHI-f8sx5aFvSz8qz7Yc9
    I uploaded it to google drive. The update is very simple:
    1. Turn on XD-05, connect to a computer with USB cable
    2. Go to directory C:\Program Files\XMOS\USBAudioStDriver_3085/W7,8,10_x64 (depends on the windows version)
    3. Run ‘xmosusbaudiost3085_dfuapp’ program,Click ‘Browse’, load the .bin file.
    4. Click ‘Start’ to update Finish!
  4. imran27
    Is it official update?
  5. Onik
    thats an old update m8
  6. kokiiiz
    Maxx134 likes this.
  7. Onik
    What does protect means in Xduo XD05?
  8. airil
    Last I saw "protect" was when my opamp chip didn't inserted fully
  9. Onik
    Right, My can opamp legs weren't sitting strong and tight inside.
    fixed it by swapping to ic opamps(AD827SQ ).
  10. Onik
    Why do I hear noise on my KZ ZSR just after plugging it on XDUOO?
    Are iems not compatible with this dac?
  11. Holypal
    Xduoo have a new product, an add-on for XD-05. Price ~50 USD. It looks like a poor man's Mojo+Poly.
    I don't have it yet, but I plan to buy it. It has Bluetooth 5.0 and separate battery.
    trellus likes this.
  12. Mouseman
    Great find! Where did you see it for sale? My Google-fu didn't find it.
  13. Holypal
    trellus likes this.
  14. airil
    Can't wait for the review of this streamer/player. Wait, is there any SD card slot in this thing?
