xDSD Gryphon: birth of a ‘head-fi’ legend
- Thread starter iFi audio
ipaddy
human bean
Nothing confusing about adding noise and throwing away informaiotnMQA can be confusing even after researching how it works...
The odd thing here is that my biggest issue in terms of stiffness is from what I understand is my only original Pentaconn jack - the PW on Traillii! Maybe others are but that's certainly the only one branded as such.
I am having an issue with all my 4.4mm cables. All of a sudden I realize I am not hearing the left headphone/IEM, and I look at the connection and it seems that the connector slipped out a little. I have to push it back in, and then if I jiggle the unit slightly it comes out. The same thing with 4.4mm input.
This is not funny. I am not able to hold the unit in my hand with the DAP, because cable will slip. Even resting the Gryphon and DAP on a flat surface, I have to be careful that the cable shouldn't move too much.
I have never had this issue with any prior DAP or amp going back a number of years (and I have quite a few, both IFI and FIIO, Hiby, etc.)
Edit: I hate to actually be asking this, as I should not have to spend more, but can anyone recommend a 4.4mm to 4.4mm connector that fits perfectly?
cleg
- Oct 14, 2011
My video about Gryphon. It's predictably good DAC
I used it with Apple Music when the jump happenedFor clarity, is the volume jump issue only something that happens with Tidal?
Well, I use my mac in clamshell mode, so the Gryphon (with its short cable) is a bit farther from my keyboard. Plus, I always have my hand on my keyboard, so it's more convenient to adjust the volume on the mac.I really don't understand, why some people want to increase the volume on the mac, isn't it more convenient to adjust it on the Gryphon?
AlexCBSN
Sub’ed
Til mojo2 comes out, this is in the top of my list. I don’t know… truly good times for audio, but man, this waiting times.
I’m torn in between cayin n6II r01 (already got the dap) , this and mojo2…
Reflecting a problem, when my sony NW-A55 is connected to the gryphon via usb, the gryphon cannot receive the A55's signal, but there is no problem when my A55 is connected to other DACs.
AlexCBSN
Does he have the Sony output cable?Reflecting a problem, when my sony NW-A55 is connected to the gryphon via usb, the gryphon cannot receive the A55's signal, but there is no problem when my A55 is connected to other DACs.
You need to look at centrance hifi m8 v2Sub’ed
_mouse_
- Nov 20, 2009
Sorry it's possible to exclude the battery when used in usb mode, so directly connected to power?
MarkParity
No the battery is the power supply, its always charged when power is connected and without the battery Gryphon doesn't work.Sorry it's possible to exclude the battery when used in usb mode, so directly connected to power?
Scubadevils
Previously known as Scuba Devils
- Nov 18, 2011
As I'm waiting (5 days now) for iFi to confirm my questions on the RMA, I decided to use it again last night - interestingly, the stiff issue has been resolved since that part fell out!
@Sebastien Chiu / @iFi audio - can you please nudge your customer service team to respond?
_mouse_
- Nov 20, 2009
Did you think it's hardware dependent or it's possible a firmware upgrade?No the battery is the power supply, its always charged when power is connected and without the battery Gryphon doesn't work.
I see the Centrance suggested before works without battery too
MarkParity
I have no way of knowing without a circuit diagram so I can't say for sure.Did you think it's hardware dependent or it's possible a firmware upgrade?
My guess is yes, a "without battery mode" could be added to the F/W as the board does power up without a battery but a low battery warning is displayed and the unit powers off after a few seconds, this low battery thing could perhaps be a firmware thing.
My another guess is the chances of iFi adding this "feature" though would be slim to none.
_mouse_
- Nov 20, 2009
@iFi audio @Sebastien ChiuI have no way of knowing without a circuit diagram so I can't say for sure.
Some word about it?
MarkParity
Here are some "better" pictures of the identifying marks on the cells in the battery if anyone is interested.
The red and black wires attached to the 1250mah cell are my solution to this cell discharging too low to recover (this problem may well affect my unit only)
iFi have not contacted me personally to ask for my Gryphon to be returned for investigation, should I expect this?
In any case I am going to leave these separate charge wires attached so that when this happens again I can quickly remove the end cover access the wire and charge the cell without removing the battery or the circuit board from the case.
To anyone saying "just return it and get iFi to fix it" I would if I 100% thought the issue could be fixed. Many people in this hobby love to tinker and improve stuff. Op-amp rolling, tube rolling. This is just my version of that.
The smaller of the two cells:
The bigger cell:
My external charging setup (Note smaller cell is 1% charged cell the bigger cell was at 99%):
The bigger cell:
