I think the cybersync volume control is an overcomplicated solution though...would be nice if they just let the analog pot work as an analog pot (i.e., let us turn off cybersync).
Yes, I know it isn't strictly speaking an analog pot, my point is that overriding OS volume control is unnecessary for controlling the volume attenuation chip.
What I'm saying is, give us a "dumb" volume attenuation chip that doesn't try to sync anything. If I turn the Gryphon down to 0, it should stay at 0 no matter what I plug it into, and if I'm an idiot running digital attenuation on my OS, let me be. At least make it an option. The "dumb" option would also help to future proof the Gryphon against the inevitable update that breaks Cybersync.
I love the idea of a digitally controlled resistor array for volume and I also see no reason to have a relationship with the OS as surely you'd be using the lovely volume knob on the Gryphon.
An option to turn Cybersync off in the menu system would be great. Kind of like the W2's HID option.
Out of interest how many steps of volume are possible with the array?
Please hurry up resolving the volume sound issue (which suddenly become MAX) !
It's quite dangerous for us and the equipment...!
I'm experience this in particular with Tidal app on MacOS.
I can be listening happily at say -30dB, then disconnect and reconnect my Gryphon and the volume jumps to +6dB when its reconnected, with the music playing where it left off.
Its quite annoying and a little dangerous, I would say its its an issue that iFi should seriously be considering recalling units over. Even if a quick fix is implemented now how can iFi ensure every owner has updated their unit.
I think I’m in agreement with you on this in that it would be nice if it could be turned off. Nevertheless it worked seamlessly with my iPhone and it’s nice not to have to leave my phone to adjust volumes, if I’m using the phone as my signal source. I’m going to try it out with Roon and with my iFi Zen Stream as a USB source and see how it plays in those configurations. Have you had problems with it in your setup?
Is the volume controlled on the analog end of the signal or is this a full digital volume pot? If the latter are there computations involved that can degrade the bit perfect signal before output as there are with other digital volume potentiometers?
I use my unit with Roon, which allows me to set volume limits upon startup. I’m going to play around a bit with this now to see if this mitigates the issue.
