X5L in my hot little hands
post-1458060
Post #46 of 69
abitdeef
Formerly known as ihatepopupads
post-1458110
Post #47 of 69
Crawdaddy
Originally Posted by rbf1138
crawdaddy- i just ordered a case from http://www.misticaudio.com/ but they seem to be sold out of both right now. The case is much better than Cowon's, though $10 dollars more. Check out pics here: http://iaudiophile.net/gallery/displ...cat=1&pos=-431
Ooo - I kinda like it! I agree that it looks much nicer than Cowon's. It mentions a removable belt clip. Wonder if it'll attach to an arm band or a running belt? Give us your impressions when you get it and try it out. Thanks for the link!
post-1458121
Post #48 of 69
Crawdaddy
I'm still learning how to operate the x5...so I'll get there, but I'm thinking that "stop" and "menu" buttons would make the operation a little easier. I get confused because the joystick / button operated differently between Music and Voice for example.
Also, the Jet Shell and Jet Audio software have some quirks. Maybe this is normal for DAP's, but I can't listen to the player when it's hooked up to the computer, I haven't figured out how to preview a song prior to ripping or downloading to the x5, and it seems to take a while to download (10-15 min for a CD of flac - could be a slow computer).
Any one have similar experience?
post-1458199
Post #49 of 69
akwok
Does anyone know where I can get the dock for the X5 regular, other than direct from Cowon?
post-1458409
Post #50 of 69
rbf1138
Atlanta
Atlanta
I'll post pics of the case as soon as I get it...it shipped Friday. I'm also still getting used to the joystick...when I press it in, sometimes I feel like I accidentally pushed it down instead, do you ever feel that? I'm also so paranoid about breaking the joystick after having the player awhile.
post-1458582
Post #51 of 69
Crawdaddy
Yes, same fears about the joystick. I guess I'm not worried about breaking it, but rather wearing it out since thats the only thing I'm touching. Given the build quality, I'm sure we'll be fine. I guess it just takes getting use to. In general a good design, but not as intuitive as I'd like. Excellent build quality and sound trumps all of my little "nit picks" though. Very happy with the purchase so far.
post-1458594
Post #52 of 69
abitdeef
I feel pretty confident with the joystick, it looks like the identical joystick that the iaudio U2 has , and my son had a u2 since they came out and has beat the crap out of the player, and all is well with the joystick
post-1459215
Post #53 of 69
uncle b
How do these operate differently? I mistakenly loaded a couple of cd's into my VOICE file and, while Windows acknowledges the discs are on there, I can access them on the player, I just get a blank screen and "No File" displyed when I press the joystick down on VOICE.
post-1460333
Post #54 of 69
SimpJee
From what I've read in this thread so far, it seems like I wont be needing that Portaphile V2. Just to confirm, do you guys think that I will need an amplifier with the X5L and Westone UM2's?
post-1460340
Post #55 of 69
TheChemist
Mine finally shipped today. Just a few more days....
post-1460479
Post #56 of 69
uncle b
Now, I am sure eventually I'll be using one of my amps with the X5L here, sooner than later, but I haven't even felt the need to hook one up yet...the sound quality of the X5L (with the UM2's, of course) is so GOOD. I haven't even started screwing around with the EQ much either, and the sound is deep and rich so far.
post-1460544
Post #57 of 69
XxATOLxX
I made the world record! I'm officially the first one to chip out part of the X5's aluminum casing
post-1468038
Post #58 of 69
HyperM3
OK, so I had to play with it immediately. First time I needed to pull out a manual to figure out some things. Not too bad just not as user friendly as I expected. Im not going to give a review as there have been enough so just some basics. Sound quality is like what people have been saying, its amazing and LOUD. Casing is solid but feels like super fine grit sandpaper, fingernails running across it can leave lines. It came with screen protectors which I used, but are they necessary? Upgraded the firmware already which was very easy. Noticed in the original firmware ALARM was spelled ALRAM. I had to laugh out loud on that.
I didnt install Jet SW, I just did drag and drop into the music folder as I had been used to with my h-120. Do I need Jet SW for anything?
Im clueless about the FLAC. How do I store/convert my music to it? I just have everything saved as WMA's. If thats a redundant question then I apologize, Im at work and dont have tons of time to search. If anyone has any direct questions about the player Ill be happy to be completely honest with opinions.
post-1468060
Post #59 of 69
LFC_SL
stop talking about your new X5's! the jealousy is killing me
what of this talk about ID3 databse support in next firmware update? due to customer naggling? - so come on - everyone send a request at spam quantities*
[size=xx-small]*joke - I'm not having Cowon sue me
[/size]
post-1468166
Post #60 of 69
abitdeef
For flac you can use jet audio to convert. It's not going to be worth converting your wma files (lossey)- rip your cd's to flac for some awesome sound quality (lossless)
