Ramsey
- Aug 1, 2006
First of all, I'd like to thank the head-fi forums for being a great source of information for my audio needs. That being said, there's one thing I haven't been able to find a good information on. (If it turns out that I just haven't looked hard enough, I apologize.)
I'd like to switch easily between my headphones and speakers on my X-Fi while in gaming mode. I've found a few solutions on these forums and elsewhere, but none that I felt were ideal...
- 3.5in drive bay front panel:
I have experience with this and felt that it lowered the audio quality significantly. (Could this have been the fault of something going on inside the computer case?)
Plus, I'd have to plug and unplug the headphones every time I want to use them, which is something I'm ultimately looking to avoid. I have a crazy concern about wearing down the jacks.
- Plugging headphones in to the headphone jack on speakers (Klipsch 2.1):
I've tried this and felt that the small loss in audio quality was acceptable. However, doing this also means that I'd have to plug and unplug the headphones every time I want to use them.
- Remapping outputs in Audio Creation mode:
While Audio Creation mode works out great for music listening, it's horrible for gaming because it causes a noticeable performance decrease.
- Simple Splitter:
I have no way of stopping the audio from going to my headphones while I'm using the speakers. (The sound from the headphones isn't that audible when the speakers are on, but I'm concerned that doing this on a regular basis would wear down the headphones. Am I being too over-protective of things?)
- Simple Switch:
I've found a couple briefly mentioned on the forums -- MK5 switch/MK10 switch and Plantronics switch. I haven't seen anything about how these are in terms of quality, though.
If you're using both headphones and speakers with your X-Fi, how are you doing it?
Are there any other (relatively cheap) solutions that I've left out here? Do my options open up significantly if I'm willing to spend more money?
- Simple Splitter:
- Simple Switch:
