WTS [U.S]: STAX 6pin Female to 5pin Male, 5m Extension Cable
Type
For Sale
Currency
USD
Price
100
Shipping Destinations
United States
Or Best Offer
Yes
post-15749467
Thread Starter
Post #1 of 4
Max_Settings
USA
USA
This is a 1st party STAX extension cable that is 5m in length that I believe dates back from the late 1980s or early 1990s. This cable was made for you to use normal bias STAX headphones on newer pro bias amps. I believe it should also work perfectly fine as a simple extension cable for pro bias headphones. Price includes shipping and PayPal.
post-15820942
Post #2 of 4
Pealy
UK
UK
Hi. Would you be happy to ship to the UK?
post-15826224
Post #3 of 4
soren_brix
... This cable was made for you to use normal bias STAX headphones on newer pro bias amps...
If you do plug in a Normal BIAS Stax earspeaker to the extension cord, and plug the other end of the extension cord into a PRO socket, the Normal BIAS earspeakers will be supplied PRO BIAS
The extension cord is not made for converting PRO to Normal.
The extension cord can be used PRO BIAS Earspeakers ->PRO or Normal BIAS socket, and Normal BIAS Earspeakers -> Normal BIAS socket
