arnobartels
- Jan 18, 2008
Good question. I would like to know how the felt disks on the Gold version are held in place.@arnobartels
How do you hold those cotton discs in place?
I use a decorative ribbon of a fairly stiff plastic fabric:
Cut to size of outer diameter of the retainer ring:
Temporary attach with masking tape:
With the cotton in place insert the retainer ring and I put 3 small blobs of glue to fix the cotton to the ribbon:
Basically you could place tape all around and insert the ring in the pads like this but I cut the ribbon to the inner diameter of the ring:
now I can insert it in the pad after I install the ring:
Or lay it on the driver and install the pads:
The ribbon can't go anywhere after you install the pads because the ring will keep in place.
