Wow! Sennheiser HD 540 Reference are so good.
Discussion in 'Headphones (full-size)' started by hairspray, Jun 29, 2013.
175 176 177 178 179 180 181 182 183 184
186 187
  1. rocksteady65
    Hi Sennsay. I would be interested to try the Velour pads on my HD 540/600, but since I'm located in Europe, I expect that the postage costs from Australia would be prohibitive?
  2. rocksteady65
    Very much agreed. I have found the HD 650 mediocre in comparison. Dull and veiled...
    sennsay likes this.
  3. sennsay
    Or, you could just buy them from the seller directly, I think the postage is 'free': https://www.ebay.com.au/itm/Replace...var=560432574135&_trksid=p2060353.m1438.l2649
    If you like velour pads, these are ok, I'm not a fan of them on the HD540s, it's not that they're bad pads - I certainly prefer them over the far more expensive Dekoni pads - but they don't have the sheer intimacy, bass depth and 3D imaging of the pleather pads, or the evenness of frequency balance. Some folks like them though and they're comfortable, but as I say, not bad sounding at all and they're rather good on the HD250s. They are also ok on the HD430s.
    rocksteady65 likes this.
  4. rocksteady65
    Thank you for the suggestion. Actually, postage is not Free or that cheap for that matter, being at over €5. Altogether, it's not that cheap for a fairly generic Chinese product. If I had the guarantee that they would perform well, I wouldn't hesitate...
  5. sennsay
    I'm fairly sure I didn't pay any postage a couple of years ago, but that's beside the point for you. There are certainly cheaper pads around, if not by much. I bought some German orhpolsters and didn't like them, didn't like the pleather pads that came with a pair of German HD430s either, too hard. For me the Wang pleathers have the goods for the Ref1s and by some measure the best overall performance, from lowest bass to the very top end, all other pads on this h/phone for me alter the tonal balance to some form of un-balance. The beauty of the combo for me is the apparent disappearance of the headphones themselves from the soundfield. Others may find it just a little too intimate, however the sound is far from being just in head, it seems to come from all around in height, width and depth. As I've mentioned previously, it's like stepping into the studio, not just observing from the mixing desk. The Wang pleathers seem to have just that right depth of pad for me, plus the fact that they have oval ear openings and I much prefer that to round openings, the oval space seems to allow for a deeper soundstage in height. Obviously I have found the right ones for me, it was an experiment that brought brilliant results that I love greatly to this day, particularly with the thinner inner foams from the Wang velour pads! The extra cost of buying both sets of pads is no drama for me because the end results are so worth it sonically.
    I did get to try a set of pleather pads that came with a set of HD540 IIs (300 ohm) that I borrowed for a while, these were deeper with round openings and while they focused the mids a little more, they added a slight thickness and weight to the mid bass, spoiling the superb balance I'm used to without any noticeable peaks and dips (although I'm sure they're probably there, just nothing dramatic that might cause me to not dissolve into the music so effortlessly). They were good, probably the best I've heard Wang-less :) and I could live with them if I had to, 'cept the owner has no idea where they came from, since they were attached to the cans when he bought them.
    Each to their own and all the best on your hunt for new pads.
  6. myusernameislove
    I am still listening to music and movies on hd540 ref1 with original used h560 velour pads on r2r11 low gain around 11 clock as my primary sound aparature. It is just perfect combination - dark liquid like sounding warmer amp with such bright airy headphone becomes something in the middle, and it is perfect. For movies DTS headphone:X from microsoft store or without it, both is great. Hd250 linear 1 with used soft pleather pads is also good, similar tonality, closed back, less amount of bass, but harder hitting. Album recommendations: Pink floyd delicate sound of thunder live and Jan Garbarek Visible world, Van Halen's You really got me tests overdriven guitar rock capabilities, Neil Young's Harvest (Heart of gold) sounds well, Phil Upchurch's Love is Strange is insanely freaking amazing on these. Hd540 is suited best for good recordings, that use space also build atmosphere, from calmer genres.
    rocksteady65, meatroll and sennsay like this.
  7. vippolito
    Hi,
    ok I read all but now I don't know what to do.......
    I HAVE AN HD540 REFERENCE.....
    1) NOW 16/12/2019 SOMEONE KNOW IF SOMEWHERE IN THE WORLD I CAN FIND ONE NOS PAIR OF COMPLETE EARPADS WITH DISCS?
    2) SENNHEISER TOLD ME THERE ARE ONLY 560 EARPADS, OK...... BUT WHAT IS EXACTLY THE WORK I HAVE TO DO TO MAKE THEY FIT ON MY 540? IT'S REALLY STRANGE THAT SENNHEISER TELL YOU HD560 IS OK FOR 540 AND SOMEONE TOLD I HAVE TO MODIFY THEM.... PLEASE SOMEONE CAN EXPLAIN?
    3) ARE THERE SOME EBAY PADS THAT CAN GIVE ME BACK THE ORIGINAL SOUND OF HD540? I ALSO HAVE 1X580 AND 1X600..... BUT 540 IS SOMETHING MAGIC.
    LET'S HELP ME. VINCENZO
  8. lithiumnk
    I got these for my hd540 & hd250. The plastic ring which comes with hd540 is required for these leatherette pads. They also come with 2 pairs of foams.
    https://www.aliexpress.com/item/32647688054.html?spm=a2g0s.9042311.0.0.2ec34c4d8QzL6E
  9. rocksteady65
    I would advise against this purchase. Not only they will alter the HD 540's sound signature, which make them so special, they can be had on eBay for a third of the price. I have tried them and while they're OK as a temporary solution, they simply aren't good enough for the task...
    lantian and lithiumnk like this.
  10. lithiumnk
    Thanks
    Do you have any recommendations?
    These are the stock pads which came with my hd540. They are made of some fabric I guess. Not sure about the exact material.
  11. vippolito
    Hi boys, I saw the photos, and I know because of mine also have a pair like this, but they are no more in production..... wait for alternative solution well seen that the chinese solution is not the one I perfer.... please help.....
    Dear
    lithiumnk
    do you know where to find a pair of original? If you know send me to +393389732511 on watzapp.
  12. jon parker
    Congrats on owning one the finest headphones ever made :)
    ALL the questions you could ever have are contained in this thread - PLEASE scroll through past pages and you will find your answers, otherwise we just have to write out the answers over and over again every time a new owner asks!
    lithiumnk likes this.
  13. vippolito
    The problem is that they are too much pages..... too much....
    It's faster that someone really inside the argument tell what he think again......
    Please help.
  14. rocksteady65
    Racism?! What the hell!? I know this is a very old post, but you are completely off base!
  15. rocksteady65
186 187
