@quimbo
Its these ones:
@Grumpy Old Git
There are 3 variants, normal, monitor and studio. As far as I can tell each one seems to add another something on top
Normal - 5-25,000
Monitor - 5-30,000
Studio - 5-35,000
by all accounts the Monitor and Studio are very rare
I wouldn't want any more than what the regular variant offers though !!
Not the best translation !!
DT 880
The beyerdynamic DT 880 is probably the headphone, about which you have to say (or write) the least, that is already said and written about this listener. bending
However, it does have reproduction properties that only professionals with the Compare sound results of much more expensive electrostatics. Because his voice coil has only a fraction of the weight conventional voice coils and its membrane differ Its nature is similar to previously known
guides
Since 1980, the DT 880 has enjoyed a triumphal march of unequaled
to step. Hardly a test that he did not confidently decide for himself has. And hardly a buyer who does not spontaneously confirming outstanding test results. A future-oriented superior quality headphones.
Technical specifications:
Transmission range: 5-25000 Hz
Nominal impedance: 600 Q / system
Characteristic sound pressure level at 1 kHz
(DIN 45581: 294 dB
Nominal load capacity (DIN 45 582)
100 mW 114 dB-7.75 V to 600 Ω
Pressing force (DIN 45581: 1.5 N
Weight (without cable): 195 g
versions:
DT 880.07 Spiral cable with
Stereo jack plug 6.35 mm
DT 880.10 Helical cable with headphone
standard plug
