fabiocrest
In my wa33 after a long tube rolling with rectifier tube I find that eh 5u4gb and sylvania 5u4gb run very well without any noise or flash
The tube flashes when u turn on the wa33? Like arcing?They claim that the WA33 operates the ER5U4G out of spec. Woo also does not recommend the Elrog as they do not recommend any tube that "flashes" upon startup.
All this information came out after I had already purchased the tube.
OK thats normal for elrog tubes. I have elrog 300B's in my red October and they do the same thing.https://1drv.ms/v/s!AnanFkRWvAbP9Rab69_poVg_YLI8?e=ZHz0pH
WA33 startup. Watch at 3 seconds left
he refused to replace my Elrog 5U4G (i had arcing in my red october with dual elrog 5U4G's) which i bought from partsconnextion and not from a local dealer.Then Thomas Mayer(Elrog owner) will likely tell you that he does not recommend Elrog for use in that amplifier. He claimed that flash meant that the WA33 was operating the tube out of spec and used that reason to deny my warranty claim on the ER5U4G. Good luck if you every have a warranty issue.
They do not do that in my Woo WA5-LE, and it runs 2 of them. I haven't had an issue in more than a year of running them.OK thats normal for elrog tubes. I have elrog 300B's in my red October and they do the same thing.
just so we arent getting confused. when you turn on your amp, the elrog 5u4gs glow straight away?They do not do that in my Woo WA5-LE, and it runs 2 of them. I haven't had an issue in more than a year of running them.
Correct, and they stay at the same luminance level the entire time. No changes brighter or dimmer. Just pure Elrog goodness.just so we arent getting confused. when you turn on your amp, the elrog 5u4gs glow straight away?
OK my elrog 300bs do the same. I thought that's what was happening in the video lolCorrect, and they stay at the same luminance level the entire time. No changes brighter or dimmer. Just pure Elrog goodness.
I mean, it depends on your budget. I love my WA33, but I'd go Viva Egoista 845 in a second. It's actually my next new equipment buy. Saving up for it now. One day! I want a black one with Porsche Guards Red insert. Should be sexy.I'm sure this has been asked 1000 times, but which amp would you all recommend for Susvara, Expanse, D8000 Pro, and Meze Elite? I'm trying to choose between the WA-33 and Feliks Envy. I have a WA-22 currently that I love to death, but it's a bit underpowered for planars. The upgrade bug keeps biting though, so I'm trying to decide on what will (hopefully!) be my end of the road headphone amp for a year or two.
I'm leaning towards the WA-33 because it's a tube rectifier amp, but I do like that Envy uses 300b tubes.
Decisions, decisions.
I wonder if that is us getting used to it, or if there is a real difference, as I feel the same way about Stratus and WA33. Wait an hour or more, and wow.I don’t know whether there’s a difference in soundstage between the standard edition and the Elite but my Elite with different tubes to the OE sound fantastic with the Susvara and 1266. The soundstage is just as big as my Envy with 300B but only once it’s real hot. Takes about an hour + to get there.
