groovyd
- Jun 29, 2012
... got some 1820's gold funkengroovin tubes on the way ftw...
Recabled my LCD-X, XC, & T1 with Norne Audio Skoll cables terminated with 1/4" Furutech Rhodium plugs only to find that the plugs do not fit into the WA7 input without having to reshape the tip. Anyone considering using Furutech plugs with a WA7 beware!
I used Moon Audio cable with Furutech FP704 plug without problem with WA7 and others amps so far
Are you sure it's not just a tight fit?
Both my stock HD650 and Oyaide 1/4" plugs were very tight fits into the WA7.
I would contact Jack and ask why it's not compatible
Sent from my LG-V500 using Tapatalk
