rage3324
- Jan 19, 2008
Is there a USB cable that you guys recommend or do most fit the bill? I have an extra HP printer cable that I could use but figure that might be not up to the task
If you don't want to spend money on an audiophile usb cable, then just get a Belkin gold usb cable and call it a day.
Any alternatives? I'd prefer a 3-4ft cable and it appears Belkin does not make less than 6ft
I was using a run of the mill 10.00 cable off amazon. I want ahead and got me a pangea 4% silver usb 2.0 cable not all that much money like 50.00 And I noticed immediately a improvement in my sound quality, The bass was way better. I was sold from then on it's worth it imo..
lol... usb cables don't work like that. either the data gets transmitted perfectly or not. it's a digital connection. there has never ever been a measurable performance difference between two non-defective usb cables.
http://www.edn.com/electronics-blogs/rowe-s-and-columns/4421042/Can-You-Hear-the-Difference-
http://archimago.blogspot.ca/2013/04/measurements-usb-cables-for-dacs.html
http://sound.westhost.com/cables.htm
While I can't argue that a $600 USB cable is going to have night and day differences, there is more to consider than purely 1 and 0's. I don't believe that I can link to other forums, but a USB's ability to shield outside interference as well as interference from the 5v line can affect sound quality. It's more about the dac chip and it's ability to handle and correct issues caused by the interference that can make it's way into the analog signal. If you feel your system is at a point where the noise floor is exceptionally low, or if you can hear the difference, have fun with trying cables. If you're in the camp that it's purely 1 and 0's, get a decent cable that isn't going to fall apart and put the money to use in other parts of your system.
Does the WA7 pair well with the Sennheiser HD800?
Yes. Even better when you add the upgrade tube power supply.
