brams
- Jan 31, 2009
Keyboard volume control doesn't work with WA8.
LCD4 and Abyss with the WA8 are not the most ideal match. You can do better with more powerful alternatives.
I heard the Abyss with the WA8 pre-production unit last fall and thought it sounded marvelous. My recently received WA8 sounds even better with my LA-900 than I recall it did with the pre-production even allowing for the unreliability of aural memory and even with the tubes still with less than 50 hours. Given this I assume the production unit would sound better with the Abyss.
Did you try with 2 tubes or 3? 3 tubes does add some punch while retaining the overall character.
No experience with the LCD4 so I can't comment on that unit.
