Woo Audio WA6 + WA6SE: Tubes, Comments, Pictures, and Advice
Oct 23, 2016 at 11:17 AM Post #2,701 of 4,838
Unbelievable, the only thing I hadn't changed was the jack adapter!
I didn't have my HP's with me as I lent them to a friend and was using the amp with some cheap HP's. The amp didn't work and I panicked!
After a two days worry, it came to my mind that one the one thing I didn't try was the 3.5mm to 6.35mm jack plug adapter!
Oh well...lesson learned...
Thanks everyone for your help!
Should have mentioned you were using an adapter.
You need to use a good 1/8" to 1/4" adapter…a lot of them are junk.
Good to hear that you resolved the issue and it was a simple fix.
Oct 23, 2016 at 12:45 PM Post #2,703 of 4,838
Yes, I should've mentioned it! I just don't know what I was thinking.
It's all good…most of the time I don't know what I was thinking either.
Oct 23, 2016 at 1:12 PM Post #2,704 of 4,838
Hello
I have a WA6-SE and a Headphone Audeze LCD-3, last version 110ohms. I am using rectifier tubes USAF 596 and drivers tubes 6gl7, 6fd7 and 6rd7. My question is in which output (High or Low) is more technically correct to my LCD-3 (110ohms). 110 ohms is considered high or low impedance?
Thank you
Oct 23, 2016 at 7:44 PM Post #2,705 of 4,838
[COLOR=454545]Hello[/COLOR]
[COLOR=454545]I have a WA6-SE and a Headphone Audeze LCD-3, last version 110ohms. I am using rectifier tubes USAF 596 and drivers tubes 6gl7, 6fd7 and 6rd7. My question is in which output (High or Low) is more technically correct to my LCD-3 (110ohms). 110 ohms is considered high or low impedance?[/COLOR]
[COLOR=454545]Thank you[/COLOR]
You can use either. Measured impedance at the source for low on the WA6SE is 15 Ohm and the high impedance is 50 Ohm. Your headphones are pretty efficient at 104db/mW so you shouldn't have an issue with either jack. See which one is quieter and allows you good volume control.
Oct 26, 2016 at 10:39 AM Post #2,708 of 4,838
Hi tube experts.
I am looking to upgrade tubes on my WA6-SE. The NOS tube I have identified, has a customs paper stamp on the glass. Do I try to remove this, or leave it on. Is it dangerous to leave it on?
i wouldnt its part of its charm
Oct 27, 2016 at 9:18 AM Post #2,710 of 4,838
Oct 29, 2016 at 12:57 PM Post #2,713 of 4,838
  Does anyone very lightly lube their tube pins with oil so their easier to install/remove, or is this not a good idea?
When i get new tubes in i always clean the pins with a fine sandpaper spray a bit of contact cleaner on wipe excess off that's all .
Oct 29, 2016 at 1:26 PM Post #2,715 of 4,838
I do the same, but I'm thinking I'm going to put the slightest coat of Super Lube oil on the pins, but I just don't know?
Thank for the reply, Mike.
You know Joseph when question like that start popping in my brain that means im getting bored my remedy is i buy more tubes lol
