TonyNewman
- May 28, 2014
this anti shuguang 274b stream is out of proportions (i guess fueled by some overreacting reviews), it's a fine sounding tube, perhaps somewhat mellow but actually has great extensions both ways and great layering on the wa6-se
Shuguang make a number of different product lines. The stock rectifier appears to be from the base line of products and it is very, very bad - as several folks on this forum have pointed out.
I use, and enjoy, a number of Shuguang products from their 'Natural Sound' and 'Treasure' product lines, from CV-181s (6SN7s) through to 845s. These are very fine tubes indeed and worth checking out.
Unfortunately, the base model rectifier would have to be about the worst functioning tube I have ever heard. Putting one of them into a WA6SE for a public demo seems self defeating to me - you are not getting anything like the full capability that the amp can deliver. Use it for amp burn in, if at all, then throw the wretched thing into the nearest bin would be my suggestion. Any other rectifier, even the modestly performing Sophia Princess or EML 274B, are hugely better.
Even better - take the retail value of the fancy Nordost cable and spend the equivalent sum on some decent tubes and keep the stock cables - I would bet some pink body parts that the SQ improvement would dwarf the difference made by the Nordost cable alone (if it made any at all, but that is a different argument for a different thread).
