Joao,
I was amazed at the price of those small i2s adapter:
https://www.amazon.com/SainSmart-Audio-Module-interface-Raspberry/dp/B00ZEWD5VK
Are you using that?
I agree $899 is an insane price for a Bridge II card.
https://www.psaudio.com/products/perfectwave-bridge/
To the others,
The Bridge II is a PS engineered options board that easily slides into the back of any PerfectWave DAC, including DirectStream and instantly transforms the DAC into a state-of-the-art network media server. You can then use any number of handheld touch screens like an iPhone, iPad, iPod or Android device to choose and play all of your music stored anywhere in your home or even over the internet.
The PerfectWave Bridge II makes high-end fun again without any performance compromise whatsoever and removes the need for the DAC to be connected to a computer allowing music lovers the world over to enjoy their digital audio collections with uncompromised performance at the touch of a finger.
Under the hood of the Bridge is a powerful high-resolution true asynchronous parallel approach based on 32-bit architecture with the core processor running at 500mHz and 256mB of high-speed DDR memory.
High resolution audio up to 192kHz 32 bits
The data, which can be up to 192kHz 32 bits, is clocked into a custom Complex Programmable Logic Device that organizes each of the 32-bit frames into the requisite I2S format. That I2S data is then clocked out with extremely low jitter fixed frequency asynchronous clocks and into the PWD through high-speed buffers isolated by a separate power supply.
The net result of this sophisticated asynchronous approach is a high-end, high-resolution network media player that does not care what the quality of the digital audio stream is over the network. What you get is simply breathtaking in its presentation heard through your system.
The music can be sent wirelessly or with a network cable and the sound coming out of the PerfectWave DAC is untouched by the transmission method. You never have to worry about setting sample rates, bit depth or any computer-like requirements. Simply touch play and enjoy.
Network Audio is the future
Network audio is the future and the PS Connected audio system places you at the forefront of technology in the high-end.
We understand that many of these technical terms and concepts may be a bit bewildering so here’s the bottom line: the PerfectWave Bridge simply, easily and without regard to how it receives the music you want to hear, plays everything in your collection perfectly and gets you closer to the music than you may have thought possible
