I think that line is intentionally there, unless you are referring to a different misalignment.I hope that slight misalignment is due to it being a prototype. Otherwise, looking good!
Woo Audio WA11 Review / Preview - Head-Fi TV
- Thread starter jude
That is what I mean... it feels like a misalignment to me, isn't it?
I asked about that and it’s part of the case design.
Ah, cool, thanks. Yeah, out of curiosity, I look into their recent video and now the line made sense.
It's a challenge when you have a seam where 2 pieces meet and then the LEDs placed at that seam point.
Let's give Woo Audio the benefit and assume they will match parts with an eagle eye in detail for aesthetics.
Should be soon. I'm getting excited!!
True. I'm excited for it too, have placed a pre-order myself with a local store here. Hopefully it works great with Ether 2.
CactoesGel
I’ve preordered this too. But I’m still contemplating between the WA11 and the WA8 (+$400). I couldn’t find any initial impressions on the web.
@CactoesGel, So I've also pre-ordered this WA11 and I'm also the owner of a WA8. Maybe I can share a little bit about why I need both.
For me the WA8, does a fantastic job of working as my transportable rig. I use it on my desk, working & use it bedside. I've also traveled with it out of the country. It's a great unit, that I don't see myself not having in my life. It's DAC is very well implemented and satisfies my taste with the warmth in sonics that I love so much via its tubes. It's a top-notch unit....But....it's heavy. Lugging that puppy around internationally was effort. Worth the effort? I think so. But if I had my choice, I'd primarily use it as I typically do, as a desktop & bedside rig.
Enter the WA11. I personally envision this being my travel rig. The specs are perfect for long haul flights. Some people have heard the prototypes Woo has shown at various Can Jams around the world over the last year or so. People seem to think highly of it. We are told that the production version is superior to the prototype. So, like many others, we are pre-ordering on the faith we have that this unit will deliver what we expect. Outstanding sonics, power, a light-weight package and a great build quality. It's not cheap...but sometimes, you have to pay for the quality.
So, I guess why I pre-ordered this WA11 is to have more flexibility to have my high-end audio on the go. Just being able to have something that I can use that has sonics that are as good as my main rig, sonics as good as my work rig and now having something that I can use on the go. Hope this helps.
Is otg adapter a must have when connecting with Android type c device? Would a normal type c to type c cable work?
I remember seeing somewhere that it works with an iPad Pro using a USB C to USB C cable. Assuming the Android with USB C device is standard enough it should work.Is otg adapter a must have when connecting with Android type c device? Would a normal type c to type c cable work?
I’m very interested in this amp, but I have a question that I hope either Woo or someone else can answer.
The WA11 is advertised as a fully balanced design. Does this mean the DAC section is also balanced, or is it only the amplifier section?
The reason I ask is there appears to be only one ESS DAC for both channels. I would assume this means the digital section then is not balanced since this would require two DACs, one for each channel.
Any help on this would be greatly appreciated.
I couldn't find the datasheet, but some chips are capable of a balanced output, otherwise it could be converted to balanced before reaching the amp, or it may have two chips. I think only WooAudio can answer that.
It would have to be a 4 channel DAC in order to be balanced: right channel positive and invert, and left channel positive and invert.
You don't need 4 channels to have a balanced output. Found the data sheet in a Russian forum, the chip has 2 pins for each channel (DACL and DACLB for the left channel, DACR and DACRB for the right channel).It would have to be a 4 channel DAC in order to be balanced: right channel positive and invert, and left channel positive and invert.
Then if you see the table that defines the pins, they are differential positive and differential negative.
And then there's an application diagram of how to get the balanced signal from those differential outputs
So assuming they are using the chip in that configuration then the WA11 has a balanced DAC section.
Thank you for your post. As long as the digital section is balanced as well, and your post seems to logically suggest it is, I’m in for the WA11. I like the form factor and apparent build quality, so I think it will be a nice upgrade for my RHA DacAmp to drive my Utopia and D8000.
