Woo Audio Amp Owner Unite
Apr 15, 2022 at 7:47 PM Post #41,671 of 41,809
ColSaulTigh
Orlando, FL, USA
Woo crew!
Does anyone have any recent experience with the WA5/WA5-LE? I'm considering it as my next H/P/A (among others). Will it be a significant upgrade from my WA6-SE's?
Thanks!
Apr 15, 2022 at 9:15 PM Post #41,672 of 41,809
SteveHulk
London
Woo crew!
Thanks!
I have the WA5LE with the upgrades and I love it.
Don't know about the WA6.
Apr 16, 2022 at 10:08 AM Post #41,673 of 41,809
musicman59
Canton, MI
I used to own the WA5-LE v1. Never heard the WA6-SE but when I was buying and amplifier I compared the WA5-LE to the WA22 because I was wanting to go fully balanced. Based on what I heard and Jack’s recommendation I picked the WA5-LE over the WA22.
I supposed the v2 is better with more power than the v1 had.
Apr 16, 2022 at 1:58 PM Post #41,675 of 41,809
musicman59
Canton, MI
Did you compare the sounds between XLR and RCA on WA5?
I am using XLR balanced cable on my wa234, but I feel the RCA should be better sounding because they should be single end.
It should be no difference in sound since the design of the WA5 is single ended not balanced. My bet is that the XLR inputs are just for convenience and not impacting performance.
Apr 16, 2022 at 5:01 PM Post #41,677 of 41,809
SteveHulk
London
I don't have any XLR cables.
Apr 16, 2022 at 5:49 PM Post #41,678 of 41,809
musicman59
Canton, MI
You're absolute correct, the XLR is just for convenience. I just heard someone else said the sounds are different, the RCA is better.
I bet is just perception or what one want to hear.
Apr 16, 2022 at 7:04 PM Post #41,679 of 41,809
pippen99
Evansville, In
It could be the RCA output of your DAC is inferior to the XLR output. My DAC manufacturer explicitly states that the RCA output is the lesser in quality.
Apr 16, 2022 at 8:11 PM Post #41,681 of 41,809
musicman59
Canton, MI
Yes, that could be. Mine has a difference in voltage output but not quality.
Apr 16, 2022 at 9:04 PM Post #41,682 of 41,809
jonathan c
western pennsylvania
I think that DAC voltage out via XLR is usually 2x voltage out via RCA.
Apr 16, 2022 at 9:37 PM Post #41,683 of 41,809
musicman59
Canton, MI
In most cases you are correct because the negative is the same collage as the positive but with inverse polarity. In my case the XLR outputs have a potentiometer where I can adjust the output voltage.
Apr 17, 2022 at 8:07 PM Post #41,684 of 41,809
OldSkool
@James824
Happy for you! Yes, the WA2 and HD800 is a perfect match that only gets better as you upgrade the tubes.
My rig sounds best with bourbon, as well. :wink:
Cheers, JC
Apr 19, 2022 at 12:21 PM Post #41,685 of 41,809
jonathan c
Here’s hoping:
