Wolfson DAC confirmed for Galaxy S3!
post-8757449
Post #811 of 947
ClausG76
Yes i did. I don't think it's software related. I was searching on Google. And came by a thread, where somebody wrote that, the jack plug is a true 1/8", and a lot of the jack plugs doesn't have the right size. I would that the phone has the wrong size. A lot of people has problems with plug. I was trying to find out if I had a bad phone.
post-8757488
Post #812 of 947
ClausG76
Ok just tested with my wife's iPhone 4s it acts just the same. I guess it was just a coincidence that it worked with my LG. Guess I'm going to bye some new phones. Just hope they will fit.
post-8757696
Post #813 of 947
Travelbug
Does jb give better sound than ics?
Sent from my GT-I9300 using Tapatalk 2
Could this have been fixed by ics custom kernels? I'm using siyah 1.5.2 on stock ics with my vsonic gr07 bass and aiaiai capitals and I don't here any hiss.
I've been holding off from upgrading to jb since it seems to have some issues still. Better sound and better battery (which jb doesnt have) are the only two things that would make me upgrade.
post-8757879
Post #814 of 947
DGriff0400
no probs with jb here.but i havent tried it on ics so i could be wrong
post-8757884
Post #815 of 947
Duncan
Moderator
True enough point there, I picked up the N7100 (Note 2) yesterday, and whilst I can hear that the Note 2 sounds cleaner as stock compared to the S3, it sounds nowhere near as convincing / powerful when compared to the S3 (ICS) with Seriyah Kernel with the mandatory tweaks.
[edit] as an aside, am charging up my Fiio E17 to see if there is a vain hope that JB on the N7100 will allow E17 playback...  If I don't reply, you know the news is predicetbly bad
post-8759330
Post #816 of 947
drjoefo
Hi my first post on the forum, although I've been reading it for some time now and have taken my first (amazing) steps into HiFi audio world! Thanks to the community :)
Not sure if this is this is the right place to ask, or if this has been answered already. I was using my S3 and iBasso D-zero with the stock Samsung ROM, which was pretty good. Recently I've changed to CM10, which I really like and the Siyah 1.6.8 kernel. Is there anyway I can use a USB DAC with this configuration?
post-8759477
Post #817 of 947
DGriff0400
dont think so.y not use samsung jelly bean? touch whiz would support the usb otg
post-8759677
Post #818 of 947
Travelbug
Is there a big difference in sq between just the s3-siyah and using the dzero?
post-8760741
Post #819 of 947
elfary
Did those background noises that appear once in a while when playing music with the screen turned off got fixed at some point ?
That's what has had me holding back for months.
post-8761383
Post #820 of 947
danny93
Yeh that got fixed ages ago haha
post-8761435
Post #821 of 947
elfary
When and how it got fixed ? what would i have to do with a stock s3 ? thanks
post-8766997
Post #822 of 947
danny93
It got fixed through an OTA update...I think Gokhan (dev of Siyah kernel) got it fixed first, no idea what he did to fix it...but no hissing anymore!
Check for a software update on your phone...if you have or havent got one I would personally either way root it and install a custom ROM and flash Siyah kernel after, it will give better SQ and also allows you to use the 5 band hardware EQ in the Woolfson DAC aswell as adding a ton of features and customisation! This is only for the international model though!
Instructions for rooting:
http://forum.xda-developers.com/showthread.php?t=1911726
or
http://forum.xda-developers.com/showthread.php?t=1701770
If you have any issues shoot me a PM I´ll be happy to help
post-8767029
Post #823 of 947
elfary
or
 Thanks a lot for such a detailed info. Actually i don't have an S3 yet because of that background chatter :wink:
Thus now S3 is back in the pool along with the Note 2.
post-8767038
Post #824 of 947
danny93
Ahh...
Well I couldnt possibly deal with a phone any bigger than the S3...just food for thought!
post-8767069
Post #825 of 947
elfary
I'm not sure i could deal with a Note 2 but as current iPhone 4S 64gb owner if get rid of it for the screen i'd want the biggest one around :wink: Still weighing it anyway since S3 is tempting as well and more manageable.
