Hello.
I have now listened to a few different Bluetooth headphones of good quality.
Either they play very open and clear, but then they feels thiny and have
I have tried this headphones the last days:
Dali io6, crystal clear sound with a bit low volume and not much bass, they was too tight fit on my head so they would not be for me.
B&O h95 3gen: the best balance so far between clear open sound and powerfull bass. Had to return them since the left speaker was having more sound then right.
Shure Aonic 50, very open and clear sound, but they have almost too much treble and they are also littlebit too tight on the head.
Last headphones i listened to was the Sony mh 1000 mx4, they had the most comfortable fit of them all, and most bass and felt most powerfull, the voices is clear and good but something overall feel littlebit more closed/ unclear vs the other i tested. And the other headphones in this price range use to have some aluminium added to the finish, Sony is pure plastic but also light and nice.
Sony is almost the clear winner, but i would like the open clear sound that dali/shure gives with the bass level of Sony. Is it any Bluetooth headset out there that can deliver both open clear sound with powerfull bass?
Or do i need to look for some wired headphones instead?
Share your experience, im open for every advice i can get in this jungle of headphones, the hardest part is to find something that not press too much trough the head
