Wired running earphones with a clip zip
May 22, 2019 at 10:12 PM Thread Starter Post #1 of 1
rdtyphn
New York
I've been using triplefi 10's while running and working out but the replacement FiiO cable has started cutting out on one side. I ordered a replacement wire but thought I should probably get something cheaper and designed for the gym. Any suggestions for a wired over the ear earphone without any mic controls for use with a clip zip?
Thanks
