Will the Sharp IM-MT880 power a DT250-80?
post-160757
Thread Starter
Post #1 of 10
Magicthyse
Better to look good than to sound good!
Or the Sharp MD-MT821 for that matter...
Both have effectively the same output (821: 10mw/chan into 16ohms, 880: 5mw/chan into 32ohms)
I've just been looking at these portable amps with ruler in hand, and they're just too big - not exactly the size of a cassette, are they? More like considerably bigger than a cassette case... That's kind of a problem.
post-160766
Post #2 of 10
wab
My Sharp SR70 mdp has probably the same output as yours. It powers the Beyer's just fine. It can go very loud but the bass is a bit lacking. I usually have it at 15/30 volume and with bass on 1.
Hope this helps..
post-160768
Post #3 of 10
Magicthyse
Thanks for the reply. Could you tell me what other phones you have had? I'd just like to get a measure of what you mean by lacking bass. These will be my alternative portable phones (the other being the V700) and I'm not looking for thumping bass - rather for a balanced sound with good presence - including, yes, adequate bass - and also with more musicality than the Sennheiser 280 Pro, for example.
post-160775
Post #4 of 10
wab
Other phones I've had include Sennheiser HD580, HD495, MX500 and Sony MDR-EX70. IMHO, of all these headphones, the Beyer's have by far the best sound directly out of a portable's headphone-jack.
The bass is still tight en deep but I know that when I power them from my integrated amp's headphone jack it's a bit better. No big deal, still much better than your V700's
They're also very musical. I enjoy mine a lot these days, also directly from portables.
post-160781
Post #5 of 10
acs236
It sounds like you'd be happiest with an altoids-boxed amp.
post-160893
Post #6 of 10
reynman
Magicthyse,
I own the 250-80 but use the r900 with its pathetic headout. It powers the 250-80 without distorting it. Good bass, warm sound, nice details. It would probably sound better on the 821 you mentioned with the higher headout. I also use the r900/250-80 with my Altoids CHA47. Brings the 250-80 to another level.
Regards - reynman
post-160917
Post #7 of 10
Magicthyse
Lookes like these are the phones for me. Thanks - yet another phone to put on order
post-160956
Post #8 of 10
Superbaldguy
It never ends, does it?
post-161017
Post #9 of 10
Magicthyse
It does get a bit ridiculous, doesn't it? I spent more than I've spent on headphones to date effectively putting a headphone socket onto my amp! I'm curious about the etys (you must be a happy bunny huh?), but well, let's wait for the forthcoming brace of phones and see where I go from there...
post-161029
Post #10 of 10
Superbaldguy
As far as pure sound is concerned, the Etys seem to be the real deal. "Accuracy" is a word that is overused to describe the sound of the ER-4P's, but it's applicable. With the drivers so close to the ear, I can hear details that were previously not part of my recordings.
This afternoon, I tried out my D22 Eggos that have sat for a week, unused. They sound wonderful, but seem a bit laidback and quiet compared to the Etys. The enhanced output of the 4P's makes a big difference with those weedy Sony headphone amps.
I really have no reason to buy another set of headphones, at least not in the near future.
