skilpad
- Jul 14, 2005
Re: TheSloth comment about the BUF634, they have been using this device for a long time even the Wadia 6 (the original one box unit) used them, they do however use a custom I to V converter module on the 861.
Re: Alwayswantmore questions, No I have not tried different cable’s. The only headphone amp’s that I have use were of my own design that makes it difficult to compare to other well-known designs out there. So far the performance gains attained from using a dedicated external amp were less than 10%. (My amp’s still needs a lot of work
Just a note on output impedance of the Wadia (BUF 634) the output stage of the BUF634 impedance is not quit symmetrical the –V side has a slightly higher value than the +V side, For Tamb = 25 deg C and Vsupply = +/-15V with Vsignal = +/-13V
Iload = 200mA we get Zout of +/- 17.5 Ohm.
Please note that his excludes the series resistance of any other components that might still be in the signal path i.e. output relay’s headphone cable.
When using the output of the Wadia to drive a headphone directly via the balanced output of the unit the transducer inside the headphone will be connected between the two output stages of the BUF634’s that implies a Zout of 2(17.5 Ohm) or 35 Ohm
The output voltage swing however will be double that of a single ended output.
The best sound achieve so far were when the output level were adjusted so that loud but still listen able levels were achieved with the digital attenuator set at 90 or higher.
With levels below 80 the sound simply collapses, (good for background listening but not for critical evaluation).
