will a D10 enough to power a DT-880 pro ? (250 ohm)?
Sep 9, 2009 at 3:07 AM Thread Starter Post #1 of 3
furyagain
i know it is kind of late to ask this.,,,
but will the ibasso be able to power the dt880 pro , dt-990 ( both are 250 ohm ?)??
if it is not..
what should i get ? for portable use
( if it is not enough my D10 will be used to power the dt-770 80ohm, when i am at work)
when i am at home, i use my forte 7.1 sound card, when compare to DAC/AMP
how does forte 7.1 rated ???
( to me it sound pretty good with the dt-880, ofcause i can't compare
as i only have that and a hotaudio bitperfect
will the D10 be much better then the fore 7.1?
Sep 9, 2009 at 3:22 AM Post #2 of 3
HiFlight
Fort Myers, FL
I will know very soon, as I have a DT-880 Pro 250 ohm enroute to me, and I plan to use it with my D10.
My guess is that the D10 will work fine unless you listen at very loud volume levels.
Mar 8, 2011 at 12:38 PM Post #3 of 3
kedrikec
Sorry for the really late reply. I have a H120+D10+ DT880 250 ohm.
DT880 and D10 works just as Ron guessed; d10 works fine
but can not provide enough power for high volume levels. But still you
can get natural projection of DT 880. cheers.
