Bunnyears
- Sep 13, 2004
It's true: Earbuds are easier to put in the ear, and just as portable as iems. Too bad that long term use of buds almost inevitably results in tinnitus and eventual hearing loss.
An iem that fits properly isolates you from external sounds which means that when you play your music you can play it at a lower volume level. Earbuds leak sound like crazy forcing you play your music at unsafe, high volume levels to hear it. There is not an otolaryngologist (MD) or audiologist (D.Aud) who approves of the use of earbuds because of this. As far as I am concerned, preserving my hearing is more important than having the convenience of not waiting for the foam tips to expand.
Originally Posted by Earwax /img/forum/go_quote.gif I don't find them particulay practical, stopping to scrunch down a foam tip before sticking it in my ear and then waiting for it to expand is annoying. Earbuds are just as portable, maybe more so since I can just stuff them in my pocket without a case, the IEM needs a case because of the foamies. |
