xxmastaxx
- Jun 30, 2010
Oh sorry not being a pro in grammar. Maybe you can tutor me?
By the way... Why pay for expensive soundcard rather then DAC?
Why not learn english first?
I probably should, than you might actually become a better typer. xD
A soundcard has a DAC but also has more hardware such as input sections, various format supports, surround support, Can amplifiers on some..etc
It is really just a matter of what you want in your system and if you have a portable system.
Some people use soundcards, some use DAC and some around here use combinations of both.
It really just depends on what you are after and what your needs are.
Why do people buy expensive soundcards then use DAC?
Soundcards can be an all-in-one solution for some people, but I think a DAC gives you a lot more flexibility. It's easier to build a stereo system out of separate components rather than running everything through a computer. I prefer to put a preamp at the center of my system - it lets me control two headphone amps, four different sources and a power amp for my speakers.
