bigshot
You should think about being more discerning with your attentions.
No you prove one usb cable makes a difference. Then you can kill the thread.
Oh, dear. What just happened after I went to bed then got up this morning?
Anyway, I earlier put forward a hypothesis about why different usb cables might make a difference to the sound. It quickly got the standard sound science mantra of show us numbers before we can discuss it. I thought the way science worked was that one had a hypothesis which was discussed and then one set about putting numbers to it to upgrade it to a theory which was then proved or otherwise. You guys seem to want the proof before you will discuss it.
We’re on page 93 and post 1382. That’s not enough?
I can only offer one highly illogical and subjective truth.
If you have my exact same equipment, and you are actually me; if you change to the AQ Carbon, you will
But nowhere else in the thread that I recollect was a similar hypothesis to mine put forward and discussed.
Or are you meaning that you think the content of the thread demonstrates a consistent unwillingness to discuss hypotheses and I should have realised that before venturing one?
If you have my exact same equipment, and you are actually me; if you change to the AQ Carbon, you will notice a sighted and profound improvement every time you listen.
The true value of this individual post is up for debate.
Yes. This is the best post maybe in a week here..........to me.So then the answer to the original thread question - "why do USB cables make such a difference" can be summarised that the difference exists in the imagination of the individual. Because that is essentially what has happened. In your sighted tests, you have introduced expectation bias, and that is why you "hear" a difference. Because your brain has coloured the output. And that's fine if you are happy with that. But being in Sound Science - the question we want to know is if there is a real audible and measurable change - with the emphasis on real and the expectation that the output should be both audible and measurable. Hint here - if it is actually audible, it will be measurable.
I totally accept that you hear it - ie audible to your perceptions.
Yet to prove - is it measurable, and is it actually real?
[1] USB being balanced will not help prevent it picking up the noise I am discussing because much of it is created by the audio device creating the digital signal.
[2] It is possibly not an issue with many systems because they might mask the problem sound and as I mentioned
[3] Design digital sources need to be quieter with respect to the noise they have in their digital circuits.
[4] The USB cable only needs to comply with the USB transfer standards in order to work properly in terms of digital transfer.
[4a] The question would be whether anything can be done to a USB cable to filter the noise.
[5] And magnitudes are fine but there is life outside of numbers.
[1] Why has nobody ever actually produced proof the wire can't affect sound quality?
[1a] Do you have proof beyond conjecture and guesswork?
[2] I'm not a digital signals processing scientist and nobody should buy a spendy USB cable unless they can try it risk-free and they definitely shouldn't take my experience as predictive for them. See? No claims whatsoever in there.
[3] I post here purely to provide a counterpoint to your bogus information of speculation stated as facts.
[4] And your antics make me laugh -
[4a] are you seriously this obsessed over a leisure hobby detail?? That's pretty astounding.
[1] Funny to note also, we are not ever reading about most of the people here doing any style of tests.
[2] It seems their opinions are cast and they have nothing more to learn. They are fully opinionated to the point of cement. I’m saying I know nothing.
[3] How could a cable have a sound signature.
[3a] Well this is SS and the question as been burning out monitor pixels for over a decade here ...
I thought the way science worked was that one had a hypothesis which was discussed and then one set about putting numbers ...
