Darren G
Thank you for the reply
I have particular interest in the in measurable differences of inaudible noise which can pass though the USB cable (if that's possible) and how the design and materials of the USB cable could affect this inaudible noise.
There are some good posts earlier in this thread that emphasize a key point. That cables pick up noise isn't news. It's precisely the motivation behind digital signaling, to transfer the information while filtering the noise. There were also comments made about the wires in the cable, the purpose of each, including why there are two data lines, reverse signals, so that common noise can be rejected (a common and well understood technique).
There were also comments about the slight possibility of a ground loop, and maybe a comment about noise from the +5 volt line, with emphasis that any competent design should isolate.
Still, if any of that concerns you, check out the Schiit Eitr. For < $200 it will isolate all 4 wires from the source (usually a computer), including outputting it's own +5 volts. Even so, Schiit still just recommends using a good old (i.e, meets spec) USB cable in, and likewise a good old (meets spec) coax cable out.
