- Jan 27, 2006
I think a lot of hostility; jawang, MomijiTMO to name a few simply comes from the idea of recabeling rather than first hand experience. Surely if I spend $300 on a headphone a $20 cable won't make a huge difference and I'm not even going to try incase I damage my headphones.
jawang - Mogami, Canare, Navships are all under $20 and are decent quality cables. You don't need to be a professional to heat up a bit of solder, you're blowing it way out of proportion. The idea that manufactures would have used the best cable is illogical and more money doesn't neccesarily equal more product. The D2000 while your on the subject is a good example; compared directly with a JVC RX700 the $30 headphone had a better SQ and controlled bass. The popular mod that attempts to correct this issue I suppose is also null and void, considering the manufacturere with their expertise didn't think this was neccesary.
