Originally posted by Moonwalker
Hi dgs!
What you've been trying to tell? Where is the push? In UPPER MID Treble? That's upper mid, upper treble, mid treble or something else?
Moonwalker |
Hey Moonwalker.
I would suggest reading my review of them here:
http://www.head-fi.org/forums/showth...=ety+er6+4s+4p
The Upper mid treble is, for me, like this:
There is treble, midrange, and bass.
These can be broken down by instruments to some simple degree:
The treble is predominantly brass, cymbals/hihats, very high vocals, violins, the very top of the guitar neck, etc.
Midrange is the rhythm guitars, most vocals, saxophones, piano, most other orchestral stringed instruments, etc.
The bass is the bass guitar, double cello, some vocals, etc.
However, this breakdown does not really capture the sweep of sound across the entire spectrum. For example, a brass instrument (like a trumpet) is capable of playing notes throughout the area of the sound spectrum delineated as "treble" and some areas delineated as "midrange." And within treble, there is a lower treble, a mid treble, and an upper treble. Then again, within each of these, the mid treble for example, there is a lower mid and upper. So, a blare from Louis Armstrong's trumpet, for example, somewhere in the mid part of the trumpet's range, would fall in the mid to upper area of the mid treble. Or Jeff Buckely's voice, when he sings falsetto, often falls into this category. On the er6, this area of the spectrum is accentuated a bit...it sounds louder all other things being equal, than the rest of the sound spectrum. This is a mild push, mind you, but a push nonetheless. This can be experienced sonically either by a sense of irritation or even pain on certain notes, other times the sonic field just doesn't feel balanced. But I digress. So, to sum up, I think of it like this:
key: U = upper, M = Mid, L = Lower
Treble has UUT, UMT, ULT; MUT, MMT, MLT, LUT, LMT, LLT
and so on...
I guess it's a little compulsive, but it's the way I conceptualize the smallest possible parts of the sound spectrum.
Was I clear?
