germanium
It's a simple truth that many recordings sound harsh on computer based playback systems, especially when copied from or played back from CD's but not from high resolution sources.
The problem arises from the fact that many CD's were mastered with a pre-emphasis. There is a 10db boost @10KHZ on these recordings. It is not the fault of the sound card or DAC that it sounds harsh. It is the pre-emphasis & the fact that computers generally do not sense & correct for this pre-emphasis. Compound this with the fact that many people here insist on running in some sort of bit-perfect mode & then wonder why it sounds bad. Note it will sound great on recordings without pre-emphasis but horrible otherwise.
I have continued using the standard windows media player & yes I tried others but sensed no real advantage, not only that but most other players would not display much of the music information correctly as well as the bog standard media player in windows, a huge disappointment. I also tried both WASAPI & ASIO with those players to no real advantage.
The message here is we need to give up bit-perfect playback in order to have truly correct balanced playback on many CD based recordings.
I have been using the Windows Media Player EQ function to correct this pre-emphasis with great success. The settings that I use are all flat up until 2KHz then at 4KHz I cut the output by 3db & 8KHz by 9db then 16KHz by 10db. this pretty accurately corrects the pre-emphasis & the music still remain lively but with out the harshness on pre-emphasized recordings. One way you can tell if it has been pre-emphasized is the upper range of piano recordings will sound unusually bright & tinkly. This disappears with my correction & the piano then sounds natural. Cymbals will also be harsh without the correction in most cases where there is pre-emphasis.
I hope this helps many of you fellow audio enthusiasts.
Ron Brandt
Ron Brandt
