Which microphone with open headphones?
post-13439858
Post #46 of 59
SomeGuyDude
There's no real reason to be using an omnidirectional mic for gaming, in fairness.
post-13440981
Post #47 of 59
Digitalis
Unfortunately it is hard to avoid them: a vast majority of headset mics and desk based microphones are either cardioid or omni - despite the proximity effect, they can pick up sounds from everywhere. A shotgun Mic might be better, as they have a very directional pattern.
post-13558797
Post #50 of 59
Digitalis
I recently got a Neat Bumblebee USB mic:
The build quality of this mic is unreal. In a word: solid. It uses a single 24mm cardioid mic capsule. The mic boom allows for the mic to be placed in such a way the sound from my mechanical keyboard is minimized. It also has a spiffy 96khz recording capability too, and the mic has very low noise for a usb mic. There is a 3.5mm jack for self-monitoring, there are controls for mic gain, a few preset frequency curves [I just use neutral] and It also comes with a snap-on pop filter. Overall, the Mic has by far the best packaging I have ever seen for such a product.
My only complaint is that is kind of ruins the red/white/black colour scheme I have with my desktop PC gear.
post-14687456
Post #52 of 59
JerkChicken
NY
NY
Mic Setup: Rode NT1A>Focusrite Scarlet 2i2 (Gen 2)
Headphone Setup: MrSpeakers Ether 2 (currently)/ Sennheiser HD660s> Fostex HP-A4BL
post-14746184
Post #53 of 59
Caster22
O.o
O.o
i am thinking to buy bm800 mic with behringer umc22.is it a bad option with open back headphones?
post-14746232
Post #54 of 59
JerkChicken
NY
NY
what do you mean in terms of bad? if you are afraid of sound leaking into the mic, then you don't need to worry. It doesnt pick it up unless you are listening at extremely loud volumes.
Plus, you can change the sensitivity of your mic using your interface or even VoiceMeter.
post-14762375
Post #55 of 59
hamison
Earth
Earth
currently using the rode procaster, but the audio technica AT2005usb or the 2100 is pretty decent for a budget option, prefer using dynamic mics over condensers
post-14764253
Post #56 of 59
ty5142
North Dakota
North Dakota
Using an at-2020 USB mic with a generic stand, definetly gets the job done but i would love to upgrade to an XLR mic like the AT-2035 for content creation.
post-14766132
Post #57 of 59
Playstation
NA
NA
I always got compliments when using my logitech desktop mic.
Imo you really cannot go wrong with a stand alone mic
post-15169488
Post #58 of 59
beepboop
post-15169573
Post #59 of 59
Amish
Riverside, California
Age
47
I use a Blue Snowball, with filter and desk mounting adjustable arm. Works perfect , is not attached to my expensive headphones and provides SQ much better than your standard boom mic. Everyone says my voice sounds rich. I use open headphones too and no one ever hears any bleed off.
