NA Blur
- Feb 8, 2011
I think you are all onto two points:
1.) The source you are using is extremely important in order to answer this question
2.) Without empirical data, which can be obtained, the responses we are all going to have will be experiential and thus not support a solid conclusion.
Point 1
If you are listening to a really bad source; say a really overly compressed mp3. Now when you run this from your PC through an amp and then into a pair of headphones. You just introduced 3 variables. a) The DAC converting your overly compressed mp3 to an analog signal your headphones can use. b) The amp and how it treats that signal and ultimately impedance. c) The headphone you are using
So to answer the questions best you need to be specific. What type of source are you using? How compressed is the audio already? What DAC if any are you using or just the DAC inside an iPod or your PC? What amp do you then want to run the signal from the DAC into? What headphones do you want to test? Without the answers to these questions you will receive a million opinions and never the real answer.
Point 2
If someone out there has multiple DAC's and Amps laying around and the ability to measure the output in terms of frequency response please post the following measurements.
Experiment
Keeping the headphones, the music file, and source the same run the signal into a DAC and then into an amp and then into your headphones. Keeping the headphones and DAC as controls take measurements through different amps. Post the various signals. Then keeping the Amp and headphones as the control test various DAC's and post those signals. The results will be from the set of tested equipment which made the biggest difference. As to the conclusion for all DAC's and all amps the data can only set a trend or at best a correlation.
I think for your question and presumably setup find the weakest link. What component do you know you have that could really use some upgrading? I know most people say that your source is the biggest thing to upgrade first then headphones. You will notice the biggest audible differences with these two upgrades.
Point 1
Point 2
Experiment
