Which iPod protectors (skin, shell) does the Sendstation Pocketdock work with?
Nov 11, 2004 at 8:05 PM Thread Starter Post #1 of 4
sygyzy
Due to the physical design of the Pocketdock, it won't properly connect to the small port opening in a iSkin.
So which skins does it work with?
Does anyone own a 4G Lajo Exo? There's a feature called 'sync port protection' which seems like it allows you to pull back the entire bottom flap. Does this imply that the models without this feature have a closed bottom? Anyone with any pictures?
Nov 11, 2004 at 8:33 PM Post #2 of 4
TWIFOSP
I have the radtech podsleev.
http://www.radtech.us/Products/Podsleevz.aspx
I like it okay. I might shop around later, but it suits my purposes right now.
Pros:
Fits it perfect, it's not bulky
Hides the fact that you have an ipod
Protects from dirt & scratches
Desensitizes the wheel to what I feel is perfect
Can use the sendstation pocket dock no problem.
Cons:
Won't protect against drops like some more stout cases
Can't use the apple dock with it (I've thought about making some small cuts to it to see if I can but have not yet. If I start checking out other cases, I'll be sure to try this)
Particles can stick to it because of the fiber type, I got black and it looks nice, but you'll notice all sorts of little bits of random stuff on it after a while. The good news is it wipes off easy.
It's a bit hard to take on and off due to the form fitting design, but not too bad.
