which IEM to get as upgrade from SE530?
Jan 4, 2010 at 7:19 AM Post #17 of 18
null audio just go through Unique melody and put a premium on top. thats who I was recommending. even custom tips extended the highs nicely and I would expect a reshell to improve it further, but they will also add a high range driver for you at the same time as well as giving you a replacable cable (one of the problems with the shures)
they do all of this at a pretty reasonable price under $200 plus your shures.
but for sure if you have the budget for upgrading to full customs from JH go for it. I mainly recommended the reshell because you mention you like the SE530 and its a known quantity, add a driver and that gives you what you want on top of what you already love.
JH13 are a safe bet as negative reactions are so rare as to be pretty much non-existent, but it still doesnt really cater to your original post and is quite expensive; so I didnt push it as an alternative
