Originally Posted by mattyb /img/forum/go_quote.gif
Thanks guys
I'm still deciding on the headphones pretty much.. but I'm faced with an "amp" problem now. I've read that you need an amp to power these high-end headphones, and that a PC sound card won't really be enough. Is this really true?
Jo-Vo: M-audio is not good for games. The sound card choices for me is restricted to the x-fi line or possibly the auzentech prelude.
From what I've read, the auzentech has preamps built into it as opposed to the x-fi? I think I read it as 5vms or something like that as opposed to 2.5vms or something similar from the x-fi. Does that essentially mean it will be twice as loud? I don't know much about this stuff.
I know that I already have a bass-line model of the sennies, which are VERY low and the sound has to be turned right up to get any good sound from it. The other model which I'm using now is actually designed for portables (Sennheiser PX 100) and they are MUCH louder! so I'm guessing they have a stronger drive built-in or something being portable? or I suppose in this case a lesser-drive thats required?
Someone said something about having their high-end headphones hooked up to the audigy 2 via the front panel. Does it make a difference when plugged into the front panel as opposed to the back of the sound card? And how loud exactly is this sound? do you have to up the volume to max to achieve a good result?
Peter Pinna, thanks for the very lengthy reply, and do not worry, I'm not offended in any way. Even tho I'm a beginner, I'm still aware that monitors are the BEST way to mix music period. Unfortunately though, I can't afford good monitors right now, and would rather concentrate on decent headphones as I have much more privacy, and can use them at whatever time I like (might wanna fool around with a track at 2am or something.)
That being said though, based on everything I've read so far.. decent headphones can still achieve very good results for this purpose! I like to mix it up personally with my current equipment (mix on headphones first, then move to speakers and fine-tune it.) My equipment is novice at best (not designed for audio production.)
I was considering for the time being probably investing in an X-Fi elite pro because it has higher quality DACS over the other models, and wanted to hook up a pair of headphones thru the elite control box (but ive heard you NEED an amp?)
I've read about people suggesting USB DACS with builtin amps etc. Sounds like a great idea, but isn't that basically just a filter that will bypass my soundcard all together? I just wish I didn't play games.. this wouldn't be so hard then
My main concern is having a sound card that will produce tight productions as opposed to what I have now (Audigy 2), and will also excel in games! and to somehow use a decent pair of headphones thru this new setup for both games & producing. Bare in mind that I will only be using a midi controller keyboard for recording in conjunction with vstis. I need something that is going to make vsti samples sound TIGHT!
My budget all up is around $650 - $700 for the soundcard and headphones. If you guys have any good possible suggestions to my ordeal.. please let me know! I've also posted another message in regards to headphones/dacs with the x-fi.
Thanks guys!
heh.. I really have to stop writing such long messages.
It's OK, write messages as long as you want.
On my office computer, I have a Creative SoundBlaster Audigy 2 ZS Platinum which has a front panel control as well as the sound card jacks on the back. The headphone jack on the front panel produces a clear sound that when it's volume knob is turned to it's maximum, produces a moderate to moderately low volume in my Proline 750's.
I don't use the Audigy 2 card for professional purposes but for personal listening and recording, it has a very nice sound, to say the least. Since you are considering using a somewhat similar card (X-Fi), and you are on a budget, I will make a suggestion for an amp.
The Behringer Amp 800 costs around $40 and especially when the price is considered, I find myself impressed by it's sound. I have never used this amp for professional purposes. It is attached to the back of my Audigy sound card on my office computer and I use it to listen to music via headphones while working on that computer. Although, as previously stated, I don't use this amp for professional purposes, I have read posts and reviews by musicians who have used the Behringer Amp 800 for professional recording purposes and have been pleased with it's performance. It is easy for me to understand why they would choose to use it. Other than it's clear, undistorted sound, it has eight headphone jacks and individual controls for four of them. It also has the capability to "receive" audio from 2 sources. Listeners can listen independently to the two sources separately.
I would not recommend this amp to an Audio Professional or an Audio Enthusiast as their "first line" headphone amp. However, I would recommend it as a secondary amp, perhaps for taking on a trip or to use in the workshop or bedroom. If you have a need for a central unit enabling multiple headphone jacks at a more than reasonable price, this might be a good consideration for you.
Here is a link to a highly reputable on-line as well as physical store that carries the Behringer Amp 800, if you want to find out more about it:
Behringer | AMP800 - MINIAMP Compact 4-Channel | MINI AMP AMP800
Before you spend too much of your budget, you might want to check out this amp. If you don't like it, you can always send it back. My thinking, here, in trying to save you some money, is that, perhaps, with this amp, you would be able to use either your current sound card or the XFI (because it costs less than others) more than you thought you could. It would, at the very least, help you in starting on your projects. One contradiction to this point might be concerning a need for a multi-input interface which neither your current sound card (Audigy 2) or the XFI provides, to my knowledge.
Someone made a comment giving the impression that there is an absolute need for a sub-woofer in mixing so therefore only monitors can be used. I admit, that I prefer to mix with monitors but with some headphones, as the technology is today, I find myself in some degree of disagreement with the idea that a sub-woofer is an absolute necessity so therefore only monitors and not headphones can be used for mixing purposes.
In reading this person's post, it became very clear to me that he / she has never heard bass (low frequencies) via the Ultrasone Pro 750's which has a clean, tight, centered and right "in the pocket" sounding bass. It's beautiful! And, that is only one example.
At the risk of being redundant, I will repeat my recommendation for you to hear the Pro 750's (burned-in, if possible as they produce a much better sound when they are burned-in). You were thinking of the AKG K 201's if I understood your post correctly. While I believe the AKG K201's and the 701's are excellent, accurate headphones, when everything is taken into consideration, I prefer the Pro 750's.
I could close this post by saying "That's my 2 cents", but with all that I've written here it's more like "That's my one dollar and seventy five cents."
Good luck!
