Which headphones do you use for PC gaming?
post-14421898
Post #346 of 373
Eulalia
Philadelphia
Philadelphia
I like AKG K712 PRO because it seems a little more compact and it really helps to cut me off from the outside world. It is important for me to focus on current assignments when I work with my resource. I had a more simple one when I was in college but It’s like chalk and cheese
Reactions: SikkNazty
post-15588361
Post #348 of 373
turbo1
Like others, I use M50s. Find them slightly uncomfortable for long periods though!
post-15591170
Post #349 of 373
CTR640
Netherlands
Netherlands
It depends on my mood and which games I play but these are I mostly use: Beyerdynamic T5p.2, Amiron Wireless/Home and Meze 99C. Wearing comfort and sound quality are superb!
post-15594712
Post #351 of 373
halcyon
Hugo TT2 w/ HD800s
Short and sweet. I like that.
But, can you elaborate?
Sure TT2 is great and so are HD800s.
What are the particular stand-outs for you in this combo? Compared to whatever else you have tried?
post-15595745
Post #352 of 373
Radio81
TX
TX
My current setup is Philips SHP9500 with a Modmic Wireless mic. I know everyone loves the BoomPro with the SHP9500, but I still use a Mixamp 5.8 wireless and there's too much echo with wired mics I've tried. Could be my environment at fault, as there's a lot of wireless devices in my home. Can't say for sure. So far I've had no complaints with the modmic wireless.
I just received a pair of Fidelio X2HR, so I will try those out. Hard to say which is more comfortable as they are different kinds of comfort. The SHP9500 are so light I barely feel them, but they are loose and prone to sliding with the slightest head movements. The X2HR have the right amount of clamping force and the headstrap is defintely more comfy that the SHP, but the SHP just seem to kind of disappear. I'll have to spend more time with X2HR.
post-15595782
Post #353 of 373
Tripokaridos
Greece
Greece
For me its 660s for light weight smoothness clearness without beeing fatigued and over 🌞 and the imaging also amazing i drive then with ifi nano
I had to also try the new Philips X3 to see how they work.
Also i like HD599 .
post-15595806
Post #354 of 373
Tripokaridos
Greece
Greece
are you playing FPS games with the 660s by any chance? if so how are they? was looking to get either the HD 700 or HD660s. anyone have a comparison for the two for mainly FPS gaming?
I have used a lot of under 200 euros headphones and listen some of 500 euros price range . To me imaging on 660s are just amazing also the sound signature its not over bright like Beyers Grados etch etch .
Think it like the smoothness of HD650 without the veil the Fast driver amd resolution from HD700 without the highs and fake Soundstage that mufles center and open up surround sounds.
Its all about taste for me it goes like this in gaming....
Low weight , Soft velur breathable pads, open back for the openess in sound , near flat sound signature on a dark side but without loosing detail , imaging so i can understand the position and the type of sound, normal soundstage so the volume per sounded object doesnt have big difference . To me 660s have all these. But again its all about taste .
Reactions: halcyon
post-15622568
Post #355 of 373
Amish
Riverside, California
Age
47
Depends but normally the Koss 95x. I use that headphone for general every day use and when i want something of higher quality I put on my Stax or one of the many others I own.
post-15623330
Post #356 of 373
bfin3
I use my Meze Empyrean. Extremely comfortable and have all the imaging, detail, and comfort you could hope for.
post-15623463
Post #357 of 373
SteelCookie
DFW Texas
DFW Texas
I use my Solaris actually, also nice with the extra isolation.
post-15623852
Post #358 of 373
Trancefreak
Audeze Mobius.
It's fabulous sound- and techwise, but I'm starting to seriously doubt it's durability ( this is my 2nd pair, 1st RMA'd )
Finish flaking of within a year, ear cushions are deforming, headband cushion is fixed, included USB-C cable failed within days on both pair, and now my right earcup started creaking.
Creaking is normal with Audeze's planar diaphragm tech, but this is excessive.
I wonder if I can RMA this replacement as well...
Yet, for games it's just phenomenal.
Reactions: halcyon
post-15629305
Post #359 of 373
pervysage
Focal Utopia + Antlion Modmic USB
post-15629687
Post #360 of 373
silentz3r0
Currently using the HD6XX. Interested in upgrading for something with wider sound stage though.
