Which do you all recommend?
Jul 15, 2009 at 5:40 AM Post #16 of 27
Sounds good. To the OP, the D2 is a great player but sounds very different from the Fuze. I think if you're looking for the most space out of a flash player, the D2 is probably the best option. I'm only considering selling mine because I got the X which is quite expensive, but if I don't sell my D2 I will just return the X.
Also, Fuze/D2 have different sound signatures, but I think the D2 is a great player for both music and video so I have some bias toward that if you plan on watching any videos.
Jul 15, 2009 at 5:48 AM Post #17 of 27
I picked up a view 9 months ago, didn't like it and it doesn't support flac Returned it and grabbed the fuze instead - much better sounding player, and flac support.
Jul 15, 2009 at 6:27 AM Post #19 of 27
All I really need is a music player. I tried the Clip for a couple days and didn't like it all, I much preferred the Fuze's SQ and the D2's. I will have to sample the View to see what I think. If the AMP3 could support 16GB Micro SDHC cards, I would get that, but as of yet no one has been able to get one to work with them.
And I would also prefer a smaller player to as it would be in my pocket a lot. That's another turn off with the S9 and View, not sure how the P3 is though.
Jul 15, 2009 at 6:59 AM Post #21 of 27
The Fuze has the same audio quality as the clip..
Jul 15, 2009 at 7:25 AM Post #22 of 27
Yeah the Clip and Fuze both use like the same chip or something and are SUPPOSED to be identical in terms of SQ. All I have is a clip, but it's not mine - just in the house. Maybe it depends on what iteration of the Fuze it is, but I think a lot of people are adamant they are the same SQ wise.
Jul 15, 2009 at 7:51 AM Post #23 of 27
Huh, that's weird, 'cause the Clip I had for a few days sounded real tinny and lifeless and the Fuze I listened to sounded much more full, warm and alive. And I listened to both straight through my SA6's.
Jul 15, 2009 at 7:56 AM Post #24 of 27
what fuze v1 or v2? EQ on?
Jul 15, 2009 at 8:23 AM Post #26 of 27
go into settings then sytem settings then info is it's v01.what ever it's a v1 fuze if .02 it's a v2 fuze.. maybe sandisk improved the SQ on the v2.
Jul 15, 2009 at 6:16 PM Post #27 of 27
Well just got back from Best Buy and the Fuze is V02.01, someone had it one Pop EQ and I switched it to normal and I still preferred it to the Clip I had. There was no longer a View on display so I couldn't check that out. But I did give this Sony a listen Sony - Walkman 8GB* Video MP3 Player - Black - NWZE438FBLK I really like the SQ on it, but it doesn't have expandable memory. So I'm going to decide between the Fuze and another Cowon probably.
