Where to get replacement material for AKG K240 Monitor baffles
  1. 93EXCivic
    So I bought AKG K240 Monitors off eBay and in the process of going thru the headphone I noticed the black fiberous paper (?) over the holes in baffle was damaged. Does anyone know what this material is and where to get it or a similar replacement?
  2. tansand
    There are medical tapes that have holes, or are breathable, you might look into that..
  3. Shoewreck
    I have the material damaged/removed in both my AKG's. Cut a circle of thin foam or any nonwoven fabric and apply it from ear side. Choose density to your preferences, denser materials lead to more bass and less headstage.
