where to buy mint boards?
post-1488061
Post #16 of 17
Pars
Can Jam '10 Organizer
Originally Posted by moeburn
I don't think you can etch tangent's boards on your own unless you've got alot of skill, aren't they double layer/sided?
Yes they are and they're a very high quality board. $5 is very reasonable. Just go ahead and add a Pimeta or a PPA board to your order to make up for the small order handling charge... you know you're going to need it
post-1489082
Post #17 of 17
mono
I was actually thinking more of a Mint-like topology rather than a straight rip of the layout, especially since home-etching without plated holes is going to require wider traces for good results. Even so, it's definitely not the first project I'd recommend for a beginning home-etcher but given some patience and either careful taping of patterns or pre-drilling reference holes to line it up, double-sided is doable.
