where can i get an UK a/c power adapter for my MINIBOX-ES
Apr 13, 2011 at 3:26 PM Post #2 of 3
Did you destroy or lose the original AC adapter or what?  lol
If you still have it, you just need one of those plug adapters.  The original adapter is designed for 110-240 volts, unless they started shipping the amp with a different one.
Apr 13, 2011 at 3:47 PM Post #3 of 3
edit actually its a 3.5mm jack
no i still have the original with the two USA prongs which i am presently sticking into my UK adapter
its just I'm a funny bugger when it comes to plus and i would rather have a power charger with the correct 3 pin plug
have looked high and low on line and cannot find an adapter with the correct specification and the UK 3 pin plug
struggling.........
got the amp from head direct, very surprised they don't give the customer the choice of what a/c they want
IE USA UK or wherever
anybody else know where i can get one
cheers for all replies and responses
