what's a good Nano skin/cover....
Nov 20, 2006 at 6:03 PM Post #2 of 5
ChicagoNB
do a search on eBay for Nano accessories and there are 1,000s to choose from. You can get an aluminum case for security against dropping, rubber one for fashion, leather to match her purse. The choices are endless and at the prices they are on eBay you could get her 10 cases and spend $30.
Nov 21, 2006 at 12:48 AM Post #4 of 5
duff138
Originally Posted by bonethugz /img/forum/go_quote.gif
i saw lots and lots of different cool nano skin/cover in tokyo japan when i was there last month. i mean it's so easy find those cover, every department stores carry them.
Fine I'll get off my ass and take a look.
There's a lot of cases out there. Lots of them are crap. I figured someone with a nano might recommend me one, to help narrow the search down.
Nov 21, 2006 at 12:33 PM Post #5 of 5
m_memmory
well if your looking for a decent skin then the BestSkinEver skin is generally well liked as is the InvisibleShield (however BestSkinEver is basically the exact same thing, works just as well AND is cheaper so that one is more well liked
Makes your nano a bit thicker (by milimetres) but other then that it's very well protected from scratches etc.
