What value resistor to use with blue LED?
Nov 12, 2004 at 9:15 PM Thread Starter Post #1 of 6
kloan
I was using a 10k ohm resistor on the (+) signal to a blue LED in my cmoy. Is this ok, or should I be using another value resistor so that it doesn't draw too much power?
Nov 12, 2004 at 9:25 PM Post #2 of 6
Well, do you know the voltage drop over the LED and suggested current rating ? Blue LEDs tend to have a higher voltage rop than e.g. red, yellow, green.
3.5V is not attypical, and give it 20 mA so it will not be too bright again...
R=U/I
If you have a 9V source then that's:
R=(9-3.5V)/0.020 = 275 Ohm. It will be safe and plenty bright in most cases
Give it around 200 Ohm if you're using an alkaline or 250 Ohm if you're using a 8.4V NiMH IMO
EDIT: 10k will work yes, but you might find that it is not bright enough. It will be fine in cases where you don't want to draw much power - but depending on it's characteristics on luminousity it might not be bright enough... a datasheet would help
Nov 12, 2004 at 9:30 PM Post #3 of 6
Well, erm what is your PSU/battery voltage? The voltage drop across a blue LED is typically 3V and you would normally like to have something like 3 mA (0.003A) through the LED. If you're using a 9V battery, the resistor should be (9V-3V)/0.003A = 2000 ohms. Depending on desired battery life, desired LED brightness and avaialble supply voltage, you'll have to modify these numbers for yourself.
/U.
Nov 12, 2004 at 9:35 PM Post #4 of 6
I'm using a 9V battery.. I know the LED is 3V min. but not sure about the other stuff.. using a 10K was plenty bright so I guess I'll stick with it..
thanks
Nov 12, 2004 at 10:18 PM Post #6 of 6
cool, thanks
